Any heavier riders on the 2022+ Spectral:on?
Ark
466
401
Newcastle Upon Tyne
@ what body weight?
pure guess based on the shocks max psi.
I'm similar weight with a different shock brand and I need the shock pumped up near it's max to get 25-30% sag
you can set it and find out without leaving the house,
What's the shock? google is telling me float x?
that guide says try started with the PSI set to your weight in lbs though so try 250 but it's probably going to be too soft by a lot
BiGJZ74
574
444
American Canyon, CA
Trying to get real world numbers. If I order a CFR and I cant set it up, thats a big waste of time. If it sets up @ greater than 50psi over body weight, I wouldn't order. It does run a Float X but unsure if they changed to a factory spec tune.
576K
