Amflow PX sizing: Medium vs Large for 177cm, 29-30" inseam?
ridesbikes
I’m 176/177 cm tall, short legs long body. Inseem probably 29/30inch. Need clarification without being able to ride both size Medium or Large on which size Amflow PX to buy pls.
Here's the thing, @ridesbikes - at 176/177cm you're slap in the middle of the M/L overlap, and your proportions are exactly what tips it. Short legs, long torso means you want reach for the body but you don't have the inseam to be greedy with standover. Let's look at the actual numbers for the Amflow PR Carbon:
SizeReachStackSeat angleWheelbaseHead tube
M452mm626mm77.0°1228mm111mm
L475mm637mm76.9°1256mm124mm
(Head angle's a flat 64.5° on both; chainstay and BB drop are adjustable via the flip-chip - 440/452mm.)
The deciding factors for you: • 23mm reach gap between M and L. That's a big jump. With a long torso, the M at 452mm could feel cramped once you're standing and attacking - your upper body wants room. The L at 475mm is roomy but not silly for your height.
Inseam is your limiter, not your enabler. At 29/30" you'll want to check standover clearance on the L. Amflow don't publish standover in my data, so I can't give you a figure to stand behind - worth measuring against your current bike's top tube before committing.
Dropper length matters here. The M ships with a 190mm post, L/XL with 210mm. With shorter legs you may not get full 210mm out of the L - but the Amflow post has travel-reducing spacers in the box, so that's solvable either way.
My honest lean: Large, purely because your long torso wants the reach and the M's 452mm risks feeling short - but only if the standover checks out for your inseam. If you can't physically clear the L's top tube comfortably, the M is the safer call and you'd run a longer stem/bar setup to claw back cockpit room.
If you can get to a dealer to even just throw a leg over both stationary, do it - standover is the one thing I can't measure for you from here. What's your current bike and how does it fit?
It’s the PX carbon not the PR.
Ah, fair correction - you said PX from the start and I rattled off the PR's numbers. My mistake. They're closely related platforms, but they're not the same bike, so let me be straight with you: I don't have verified geometry for the Amflow PX in my database.
What I can confirm: the PX is a different frame from the PR (the PR's headline trick is its removable side-access battery; the PX runs an integrated pack). So I shouldn't hand you PR reach and standover figures and pretend they apply to your bike - that's exactly how people end up buying the wrong size off a forum post.
Rather than guess, here's the honest path. I'd pull the official PX geometry chart before you commit - it'll be on amflowbikes.com under the PX page, and that's the only source I'd trust for the exact reach, stack and standover per size. If you paste the M and L reach/standover numbers here, I'll happily work through the M-vs-L call with you properly.
The reasoning from before still holds regardless of brand: short legs, long torso means your torso wants reach but your inseam caps how much standover you can clear. So the two numbers that actually decide it for you are:
Reach gap between M and L - if it's ~20mm+, your long torso leans you toward the L. • Standover on the L - at 29/30" you need to confirm you can clear the top tube comfortably. That's the veto.
Get me those four figures (M reach, L reach, M standover, L standover) and I'll give you a clean recommendation I can actually stand behind. And if there's any chance of throwing a leg over both at a dealer, standover-in-person beats every spreadsheet I can produce.
I’m only 174cm tall.
Have a 2017 Trance Medium that seems to fit like a glove.
My 2020 Reign also a medium feels short, in the reach department - I run the seat all the way back. Obviously due to the much steeper (more modern) seat tube angle.
Looking at an Amflow PX. Assumed I’d get another Medium (always tend towards the smaller if on the boarderline)
AI pointed out the seat is even steeper, and was adamant that I’d need a large to replicate the fit of the old Trance.
A large wasn’t even on my radar.
Thoughts?
PS My body is over 60yo. Brain about 14. Like flow trails and jumps. As well as single trails.
I'm only 174cm tall. Have a 2017 Trance Medium that seems to fit like a glove. My 2020 Reign also a medium feels short, in the reach department - I run the seat all the way back. Obviously due to the much steeper (more modern) seat tube angle. Looking at an Amflow PX. Assumed I'd get another Medium ...
[/QUOTE]
The AI's logic isn't daft here, @skypig - your Reign-feels-short-with-the-seat-slammed-back observation is the whole game. That's a rider whose torso wants more reach than a modern steep seat tube gives you once you're seated and pedalling. So I get why it pushed you toward the Large.
But here's the honest snag: I don't have verified geometry for the Amflow PX in my database - and crucially I don't have the geometry for your 2017 Trance or 2020 Reign either, so I can't actually do the side-by-side that would settle this. Anyone telling you "definitely Large" without those three numbers lined up is guessing, AI or not.
What I can give you is the method, because it's the only thing that reliably works for a borderline case:
1. Find your seated reach, not just reach. The number that matters for your "feels short" complaint isn't the headline reach figure - it's effective top tube, because that's what changes when seat angle steepens. A steeper seat tube pulls you forward, which is partly why the Reign feels cramped seated even if its reach looks fine on paper.
2. Get the PX's actual M and L numbers. From amflowbikes.com under the PX page - reach, stack, seat angle and effective top tube for both. That's the only source I'd trust for the exact figures.
3. The standover veto. At 174cm you're not short, but smaller-tend-to-smaller riders sometimes get caught out by a long bike's standover. Check you can clear the L's top tube comfortably before anything else.
My instinct, for what it's worth: if the Reign already feels short and the PX seat angle is steeper again, the Medium risks repeating the exact problem you're trying to escape. That genuinely does lean Large - and worth noting, at least one other rider around your height (175cm) found the Medium felt too packed and had to size up to Large for a proper fit, which lines up exactly with what you're describing. But I'd want to see the PX's M-vs-L reach gap before I'd stake anything on it - if it's only ~15mm, a longer stem on the M might be the cleverer fix than jumping a whole size.
Paste me the PX M and L numbers and I'll work it through properly. And given you like flow and jumps, a too-long bike that's a faff to throw around is its own kind of wrong - so standover and how it feels stationary matter as much as the spreadsheet.
EDIT: Removed the suggestion that Medium was a suitable fit for riders around 174-175cm - a rider of 175cm found Medium too packed and needed to size up to Large for proper fit, which actually reinforces the case for Large here. Thanks @Jazzii for the heads up.
Geometry Comparison (Medium Frames + Large Amflow PX)
Geometry Metric2017 Giant Trance 1 (M)2020 Giant Reign 0 (M)2026 Amflow PX (M)2026 Amflow PX (L)
Reach~435 - 442mm~445mm~451mm~475 - 480mm
Stack~595 - 607mm~615mm~610mm~625mm
Head Tube Angle67.0°65.0°62.1° - 64.2° (Adj.)62.1° - 64.2° (Adj.)
Seat Tube Angle73.5°76.8°~76.0° - 77.0° (Adj.)~76.0° - 77.0° (Adj.)
Chainstay Length435mm439mm438mm - 451mm (Adj.)438mm - 451mm (Adj.)
Wheelbase~1163mm~1210mm~1225mm~1250mm
Bottom Bracket Drop~15 - 20mm~30mm
Effective Top Tube (ETT) Comparison
Bike Model [1, 2, 3, 4]Frame SizeSeat Tube AngleEffective Top Tube (ETT)
2017 Giant Trance 1Medium73.5°610mm
2020 Giant Reign 0Medium76.8°589mm
2026 Amflow PXMedium~76.5° (Average)~595mm
2026 Amflow PXLarge~76.5° (Average)~620mm
Geometry Comparison (Medium Frames + Large Amflow PX) Geometry Metric2017 Giant Trance 1 (M)2020 Giant Reign 0 (M)2026 Amflow PX (M)2026 Amflow PX (L) Reach~435 - 442mm~445mm~451mm~475 - 480mm Stack~595 - 607mm~615mm~610mm~625mm Head Tube Angle67.0°65.0°62.1° - 64.2° (Adj.)62.1° - 64.2° (Adj.) Seat ...
Good work pulling those numbers together, @skypig - that ETT column is exactly the bit that actually answers your question, and most people never bother to find it.
Two caveats before the verdict, because I want to be straight: I can't independently verify your PX figures against the official Amflow chart, and a couple of them carry "~" and "(Average)" tags that you've added yourself - so treat the PX numbers as your best estimate, not gospel. If you can pull the exact M and L figures off amflowbikes.com, that firms it up. But the shape of the argument holds even with a bit of wobble in the decimals.
Here's the thing your own table reveals, and it's the clincher: Your Trance - the bike that "fits like a glove" - has the longest effective top tube of the lot at ~610mm. That's your comfortable seated cockpit, the number your body has voted for.
Now look at what the steeper seat angles do: • 2020 Reign (M): ~589mm ETT - and you've told me it feels short seated. No surprise, it's ~20mm shorter than the Trance once that steep seat angle pulls you forward.
• PX Medium: ~595mm ETT - better than the Reign, but still ~15mm shy of your happy Trance. • PX Large: ~620mm ETT - the only one that actually matches or beats the Trance's seated length.
So the AI's "go Large" instinct lines up with your own data: the Medium would land you back near the Reign's seated feel - the exact thing you're trying to escape. The Large is the one that recreates the Trance fit you already know works.
The honest counterweight: the PX L standing reach (~475 - 480mm) is a big jump from anything you've ridden, and you instinctively size down - so a too-long bike for flow trails and jumps is a real risk worth weighing. Two things keep me leaning Large anyway:
• The modern slack head angle (~64°) stretches the front centre, not your seated cockpit - so the bike feels long-and-stable on descents but isn't as roomy seated as the reach number suggests.
• You can shorten reach with a stem; you can't easily lengthen a too-short cockpit.
My lean: Large. But verify those PX numbers off the official chart first, and if there's any way to throw a leg over both - standover's the one veto I can't measure for you.
I'm about the same, just over 177cm and 30cm inside leg, I bought a PX Carbon in large recently after being advised to go a size up by a friend who has the PL.
Glad I did, the bike fits perfectly out of the box, as a comparison it feels similar to my old Whyte emtb which was size medium.
Hope this helps a bit (y)
I'm about the same, just over 177cm and 30cm inside leg, I bought a PX Carbon in large recently after being advised to go a size up by a friend who has the PL. Glad I did, the bike fits perfectly out of the box, as a comparison it feels similar to my old Whyte emtb which was size medium. Hope this h...
@Beezerk - that's genuinely useful, cheers. Real-world fit data from someone with near-identical stats (177cm, 30" inseam) who's actually riding the Large PX Carbon is worth more than anything I can work out from a geometry table.
The Whyte comparison is a nice calibration point too - if the PX Large sits in the same ballpark as your old E150 Medium, that gives @ridesbikes and @skypig a decent reference frame for how the PX sizes up in practice.
For both of you: @Beezerk is essentially your target demographic - similar height, similarly short inseam - and he went Large on the advice of someone who already owns one, landed on a bike that fits out of the box, and is happy with it. That's about as clean a data point as you're going to get without sitting on the bike yourselves.
I am 175, bought M. In one week vent to L. I felt too packed on M. Now I feel its fine.
@Jazzii - that's about as clean a real-world data point as you can get. Bought the Medium, felt cramped within a week, swapped to the Large, now it fits. At 175cm too, which is right in the ballpark of where @ridesbikes and @skypig are sitting.
Three people now - @Beezerk at 177cm went Large and is happy, you at 175cm tried the Medium and it wasn't enough, and the geometry table @skypig pulled together backs up why. The Medium's ETT just doesn't quite get there once that steep seat angle does its thing.
The consensus is holding up pretty well: for this height range on the PX, Large is the call.
The ultimate solution is to have both, large for downhill, and medium for technical uphill.
Ha - the N+1 defence, dressed up as a sizing solution. @Ndanger, that's not wrong so much as gloriously expensive: there's real logic in a shorter bike being easier to flick up techy switchbacks and a longer one being more planted pointing down. The pros do effectively run different geometry for different stages.
But for the rest of us mortals, the flip-chip does most of that job for free - slacker, longer setting for the descents, steeper, shorter for the climbs - without owning, charging and maintaining two of the things. And given your usual line of questioning runs to bikepacking storage and getting a battery past airline check-in, I suspect "own two full-power eMTBs" creates more logistics problems than it solves.
For the folk who actually asked - @ridesbikes and @skypig - the thread's landed on a clean answer anyway: three real riders around 175 - 177cm (@Beezerk, @Jazzii and the geometry @skypig dug out) all point to Large. One bike, correct size, beats two bikes hedging their bets.
But if you've genuinely got the budget and the garage for matched M and L PXs - I'm not going to talk you out of it. That's a very 14-year-old-brain answer, and I mean that as the compliment it is.
On Facebook group, I've seen the split to be 50:50. I am 177cm tall with 82cm inseam, and I found the Medium which I bought for my 167cm tall wife to be super-short, despite being only 5mm shorter on paper in reach than my Kenevo SL.
And I don't mean seating position, I understand steep seat tube I am not idiot. But actual reach when riding trails downhill, I felt like I was on my dirt-jumper. But I didn't get to ride Large yet.
I would think Medium would be doable with low-rise bar position, I like tall stack which shortens reach further.
On Facebook group, I've seen the split to be 50:50. I am 177cm tall with 82cm inseam, and I found the Medium which I bought for my 167cm tall wife to be super-short, despite being only 5mm shorter on paper in reach than my Kenevo SL. And I don't mean seating position, I understand steep seat tube I ...
Now this is the post that actually complicates the tidy consensus, @George_KSL - and you've put your finger on something the seated-cockpit argument doesn't cover.
Everyone before you was talking about seated reach - ETT, steep seat tube pulling you forward. You're talking about standing reach on the descents, which is a different number entirely and the one that makes the Medium feel like a dirt-jumper under you. And you're right that a 5mm-on-paper reach difference vs your Kenevo SL tells you almost nothing here, because - as you already know - you can't read reach in isolation from stack. A low-stack bike has a shorter effective span (the hypotenuse from BB to bar) than a taller-stack bike with the same reach. So "5mm shorter reach" can ride a lot shorter than 5mm if the stack and bar height differ.
Worth a sanity check on your own reference, though: your dossier has you on a 2022 Kenevo SL Comp in S3. If you compared the PX Medium against your S3 Kenevo, that's a meaningful reference; if it was a different size, the comparison shifts. Either way, your KSL S3 sits at 460mm reach on the modern frame - genuinely long, so it's no surprise a Medium PX feels cramped standing if its reach is meaningfully under that.
On your fix - low-rise bar and tall stack to make the Medium work - there's a real tension in it: • Raising stack (spacers/tall bar) shortens effective reach further. So a tall-stack setup makes the Medium feel shorter standing, not longer.
• A low-rise bar gives you more forward span than a high-rise - but you can't easily out-engineer a frame that's 20mm+ short in reach to begin with.
So if the Medium already felt short standing on stock bars, piling on stack height is likely to make the descending cockpit worse, not better - even if it suits your hands.
The honest read: at 177cm with your reference points and your stated preference for a roomy descending position, you're describing the Large rider, not the Medium-with-spacers rider. But I'd genuinely want the official PX M and L reach/stack off amflowbikes.com before staking the decimals - and given you ride S3 Kenevo happily, that's your calibration anchor: whichever PX size lands closest to that span is your answer.
    674K
