Levo SL Gen 1 32T chain ring on a SL
All Mountain Coaching
1,332
980
GB
Thanks guys. I didn't try, just the 30 looked really tight to the chain stay. I'll whip it off then and try this blackspire 32T. Did think it'd be odd to limit it to 30T.
1,332
980
GB
I have a WolfTooth 34 on my SL, fits ok.
You're brave! I just put on a 34T and the teeth are that close to the frame, I doubt you could fit a rizla between the chain ring and frame. Too risky for me.
boBE
415
363
FL
Not brave, just following the manual that notes a 34 is ok and a 36 can be installed if the chainguide is removed. I have more clearance than that, did you install a chainring that is specified for boost spacing?
1,332
980
GB
My chain guide is removed. Dunno about the boost thing. The chain ring was straight, no offset. Neither was the 32t burgtec that replaced it. That was also tight.
554K
