2025 Rise Lt -Coil
scarl
42
sacramento
Just picked up the New Lt - only a couple of rides - IMO it does ride more composed than my 2022 M-team and still remains agile and playful. EP801 is definably an improvement. Very supportive and excellent battery range with the reduced watts
Want to go coil - Does anyone know of other coil shocks that fit / work other than Fox DHX2?
b33k34
282
103
What size and model? when did you order it?
(also interested in coil options - the RS super deluxe coil I have on my Enduro bike is impressive and a decent chunk cheaper than the fox)
scarl
42
sacramento
M20 - Medium. I've had it about a week.
I emailed Orbea directly . I didn't get a straight answer. Basically they only recommend the new fox float , Float X or the DHX. the Float performance isn't enough shock for my riding. I already have the Float ( which would work for me ) but really wanted the DHX2 not the DHX. I like to adjust HSC and from what I understand you can't on the DHX.
ebsocalmtb
253
290
Southern-Cal
Get a DHX/Marz Bomber CR and send it to avalanche. I have the dhx2 on my rise, the HSC adjuster doesn't really add HSC but instead adds harshness. I ended up sending it into fluid focus for their custom base valve piston and shim stack tuning and now the HSC is usable. Even then however, with the smaller diameter shock shaft that the DHX2 has, it's more fragile and susceptible to side loading because of the yoke link/design the rise uses. The DHX/Marz bomber is the more durable tool for the job and with avalanche tuning, it will be the better performing shock anyway.
oettam20
114
116
Lugano
The new Vivid Coil ultimate fit into the frame, and it works really well.
The lock out is perfect for pedalling in a efficient way uphill. Downhill it's much more constant and predictable than the original Float-X
scarl
42
sacramento
You fit Vivid Coil Ultimate to a Rise LT ? Nice May not matter as much with New Frame - as even the Mediums now are shipping with DHX but what frame size are you on?
Inde_Si
27
19
France
Anyone tried a Vivid or Super Deluxe?
I've seen one with the vivid Air, so the vivid coil should fit
(Not my bike, just found the photo elsewhere)
oettam20
114
116
Lugano
I’m on a size large. With the vivid in there is still room for a 700ml bottle in the cage.
stefighters
42
9
France
could you give us your feedback on vivid and rise LT?
i am looking to replace my fox dhx.
thanks.
578K
