I do not want more power from my SL. And the Rise is heavier part for part.
but the range extender of orbea rise does only charge the main batterie, you can not ride the orbea rise if the main batterie is slightly empty. check the manuel under battery/extender!!Check out the Orbea Rise threads in this very forum. Owners are riding easily 2-4 hour rides. I personally have riden max 2 hour rides with mostly trail/50Nm setting and still had 1/3 battery left. Range extended is also available for the Rise similar to SL.
Rise motor 60 N*M; rpm 75-90 (let's use 80); equals about 500 W. If the motor is 90% efficient (generous) the battery has to provide 555 W. The 360 W*H battery will be drained in about 40 minutes yet Orbea claims 2 hours at that level. Someone is breaking the laws of physics, my guess is it's their marketing department.![]()
I do not want more power from my SL. And the Rise is heavier part for part. If a new SL comes out and is heavier due to motor and battery I’d be gutted.
The only way more power can be put through the SL motor as it stands right now is to put in a steel cog…. And nobody (unless deaf) wants that.
Not sure I'm following. My Rise is lighter than any SL as far as I know. I'm in just under 40 lbs with pedals in current trim.
Do you ever feel your Rise may not be beefy enough being so light? I only ask as a buddy mentioned he rode one recently and felt it wasn't burly enough for him and didn't feel like he could push it as hard. Just relaying what I was told so it would interessting to here your perspective.
37.
I just made that up.
What do you mean by "modified"? ?
As far as you know... IndeedNot sure I'm following. My Rise is lighter than any SL as far as I know. I'm in just under 40 lbs with pedals in current trim.
My SL Comp carbon M, stock tubeless and pedals is 39 LBS
Anyway weight-weenie discussions in ebike world should not take place.
LOL. I could easily make mine lighter - it would suck to ride it though!
Apparently you still did not get the point...
I wanted to demonstrate, first that you was wrong about your Rise being lighter than any SL (this is rather the opposite at equivalent build), and second (most importantly) how absurd it is to argue about which EMTB is lighter when the difference is sub 1kg.
I'm sure you made the right choice (for you) going for Orbea rather than Spe, and I'm convinced you can build a sub 35lbs kit.![]()
My XL SL is 16.4kg (36lb) with pedalsNot sure I'm following. My Rise is lighter than any SL as far as I know. I'm in just under 40 lbs with pedals in current trim.
Anyway back OT... Any more news on the next SL yet?
What's the full spec of that Gaz?My XL SL is 16.4kg (36lb) with pedals
I can see the first part being possible, or even likely, but the second? Surely if they were going to do that they would have debuted it on the KSL.Levo Gen 3 geometry and power upped a tad is what I heard from someone at specilized.
Guess it depends when they started work on the KSL and what they'd decided to run with.I can see the first part being possible, or even likely, but the second? Surely if they were going to do that they would have debuted it on the KSL.
