2022 Heckler MX links from Cascade Components
Hickey300
8
18
Florida
I meant prototype. You said these were the prototype links before they released them for production. I assume it’s the same thing?
SEBA
364
137
French Provence High Alps
what are the advantages of cascade link ?
would it touch my schock ?
LautSprecher
76
68
Will a 2024 Fox Float X2 fit into a MX LT link? In my understanding it will not fit.
Got response from cascade-link-team below 5 Minutes: they "recommend" Float X because of the tight space there but did not try it by themself.
SEBA
364
137
installed cascade link in my Heckler 9 mx , went OK but touch my shock so I grind a bit the upper link to avoid that
bb seems higher but need to find the correct psi in shock , definetly more travel and sure it'll be very plush
will fit a zeb 170 soon , will update with picture of the whole bike
and find an idea of fitting a little multitool in the upper link 😅 but don't know if it's a good idea
SEBA
364
137
after and before
so far I tested 20 min , 210psi in shock (230x65) 40% sag ( because I love so much when plush++ ) and it runs smooth , much more travel possible
dont know about the silver touch ,.what do you think silver or black ?
Hannes
Hallo zusammen - Grüsse aus Deutschland.
Habe mir mir heute auch das Link bestellt.
Und werde Fox DHX Dämpfer verbauen.
Bin ca. 80kg mit Bekleidung schwer.
Hab jemand hier einen Tip wegen der Federrate Härte für mich.
Wie sind die Erfahrungen mit dem CC Link.
576K
