For Sale (BIKE) 2021 Trek Rail 9.8 XT *NEW FRAME* REDUCED* Medium: £4000
Barnicles
57
20
Uk
Bike / Product Year: 2021
Manufacturer: Trek
Model: Rail 9.8 XT *BRAND NEW UNUSED FRAME*
Size Medium
Asking Price: £4000
Location Worthing
Description 2021 Trek Rail in size medium. The bike has covered about 750 miles but may rise slightly as it might get used. The frame has recently been replaced through my insurance company as I damaged the frame. The frame has been invisframed and will be sold with a spare invisiframe kit.
Bike is pictures with carbon wheels but will be sold with the Ibis s35 alloy wheels with Hutchinson Griffus front and rear
Pedals will be included.
2 x keys and charger.
Bank transfer on collection.
Frame:OCLV Mountain Carbon main frame & stays, Removable Integrated Battery (RIB), tapered head tube, Knock Block, Control Freak internal routing, magnesium rocker link, Motor Armor, Mino Link, ABP, Boost148, 12mm thru axle, 150mm travel
Rear Suspension:RockShox Super Deluxe Ultimate RT3, DebonAir spring, Thru Shaft 3-position damper, 230x57.5mm
Fork:RockShox ZEB Select+, DebonAir spring, Charger 2.1 RC damper, eMTB optimized crown, tapered steerer, 44mm offset, Boost110, 15mm Maxle Stealth, 160mm travel
Motor:Bosch Performance CX, magnesium motor body, 250 watt, 85 Nm, 25km/h
Battery:Bosch PowerTube 625
Controller:Bosch Kiox
Number of Gears:12
Gear Shifters:Shimano XT M8100, 12 speed
Chainset:E*thirteen E*spec Plus, 34T
Chainrings:34T
Rear Cassette:Shimano XT M8100, 10-51, 12 speed
Chain:Shimano XT M8100, 12 speed
Rear Derailleur:Shimano XT M8100, long cage, 51T max cog
Pedals: Nukeproof composite
Rims: Ibis s35
Front Hub:Ibis
Rear Hub:Ibis
Tyres:HutchinsonGriffus
Brakes:Shimano SLX M7120 4-piston hydraulic disc
Handlebars:Bontrager Line Pro, OCLV Carbon, 35mm, 27.5mm rise
Grips:Bontrager XR Trail Elite, alloy lock-on
Headset:Knock Block Integrated, 58-degree radius, cartridge bearing, 1-1/8" top, 1.5" bottom
Stem:Bontrager Line Pro, 35mm, Knock Block, Blendr compatible, 0 degree
Saddle:Ergon
Seatpost:Bontrager Line Elite Dropper, internal routing, 31.6mm
Barnicles
57
20
Uk
Recently been re listed for sale after deciding to keep it. Please message if you have any questions.
578K
