Trek Rail 9.8 XT 2022, size medium. 160mm front, 150mm rear travel. Excellent condition 750w battery, Gen 4 Bosch motor. Invisiframed. Mullet set up with spare 29 wheel included. Balance of warranty transferable. All paperwork, battery charger, keys included. 500 miles. Price £4300
Cushcore tyre inserts (£100), Peddles (£50) Burgtech mk5 & mudguards(£30) can be bought separately if wanted.
Full Spec:
Frame: OCLV Mountain Carbon main frame, 1.8" lower head tube, Removable Integrated Battery (RIB), Knock Block 2.0, guided internal routing, 34.9 mm seat tube, magnesium rocker link, Motor Armour, Mino Link, ABP, Boost148, 12 mm thru axle, 150 mm travel
Fork: RockShox ZEB Select+, DebonAir spring, Charger 2.1 RC damper, eMTB optimised crown, tapered steerer, 44 mm offset, Boost110, 15 mm Maxle Stealth, 160 mm travel
Shock: NEW RockShox Super Deluxe Ultimate RT3, DebonAir spring, Thru Shaft 3-position damper, 230x57.5mm
Wheels:
Bontrager Line Comp 30, G609 alloy, Tubeless Ready, 6-bolt, Boost110, 15 mm thru-axle
Bontrager Line Comp 30, G609 alloy, Tubeless Ready, 6-bolt, Shimano MicroSpline freehub, Boost148, 12 mm thru-axle (Both 27.5 & 29 come with bike)
Tires: Schwalbe Magic Mary Tubeless Ready, 29x2.6" & 27.5 x 2.6”
Shifters: Shimano XT M8100, 12-speed
Rear Derailleur: Shimano XT M8100, long cage, 51T max cog
Crank: E*thirteen E*spec Plus, 34T, 165 mm length
Cassette: Shimano XT M8100, 10-51, 12-speed
Chain: Shimano XT M8100, 12-speed
Saddle: Bontrager Arvada, austenite rails, 138 mm width (back to stock)
Handlebar: Bontrager Line Pro, OCLV Carbon, 35 mm, 27.5 mm rise
Stem: Bontrager Line Pro, 35 mm, Knock Block, Blendr-compatible, 0-degree, 45 mm length
Headset:Knock Block 2.0
Grips: Bontrager XR Trail Elite, nylon lock-on (back to stock)
Controller: Bosch Kiox 300 with Anti-theft solution
Motor: Bosch Performance Line CX
Colour: Dark Prismatic/Trek Black
Full Spec:
Wheels:
Seatpost: Bontrager Line Elite Droppper, 150mm travel |
Brakeset: Brake | Shimano XT M8120 4-piston hydraulic disc |
Brake rotor: | Shimano RT76, 6-bolt, 203 mm |
Battery: Battery | Bosch PowerTube 750 |
Charger: | Bosch standard 4 A (230 V) BES3 charger |
