2019 Levo Comp SRAM GUIDE RE brake upgrade?
stu11
stockport
I can also confirm Guide RE's have a lot of modulation, was quite happy with them on 2020 Levo Comp, but a good deal came in for Code RSC which I could not refuse ...
Hi.
I've got a set of code rsc lines up but I'm reading the hose isn't compatible from re to rscs, just wondering what you did to get them to fit pls?
DaveNewing
88
20
Hi.
Hi,
I ended up taking it to my LBS, they removed the old guide RE hose and fitted the code R hose and bleed it for £30.00
salko
1,370
957
SLO
Yes I confirm hose is not compatible between the two. Guide RE uses olive, while Code RSC uses factory crimped banjo fitting. I had to reroute new hose from Code RSC through the frame.
578K
