Kenevo cambo
Wondering if anyone else out there with a 2018/2019 Kenevo has seen this where the shock mounts to the frame there is a gap between the 2 welds and there appears to be movement there.
I had a nasty creaking noise coming from the frame that I was having all sorts of issues finding the cause and when I sprayed some chain lube into this crack the noise went away......
The top section of this area of this frame has a continuous weld whereas underneath there is a gap in the weld.
Could be normal but keen to see what other kenevo's look like just in case it needs further attention.
