• Warning!!
    UK Pedelec Law
    Worldwide Laws
2019 gearing? Also de-restricted top speed numbers. How fast can you go?
phdatsun
10
16
TAHOE VISTA, CA 96148
Hello I have de-restricted my bike with a peartune. I can get to about 30mph easily and my legs are moving pretty good. I bought a 38th chainring to replace the 32th and it is in the way of my chainguide so to use it I will have to remove the guide. Has anyone done this to a 2019 Levo successfully? Im also curius of the top speeds you guys are hitting derestricted. Also has anyone tried a 12speed setup with a big chainring? I think that may be my next step but not sure if a big chainring and big rear sprocket will be compatable.
De restricting doesn't alter your top speed, it only alters the assistance you are getting on the way to the top speed - as you have clocked the speed is governed by the gearing. You will have the same top speed assisted or unassisted.
I personally would not go with an option that means removing the chain device, unless you are mainly riding on road.
Also check the 38t doesn't hit the chain stay at any part of the suspension movement.
phdatsun
10
16
Derestricting for me made a huge difference on top speed for me. I went from barely over 20 to over 30mph. I get what your saying but if you dont have the leg power to pedal faster than 20 your not going faster. So de restricting it gave me a huge top speed increase. Now im out of gearing but could easily go faster with gearing.
I understand that, just pointing out that it doesn't actually make the bike capable of going faster, though it may make you better able to reach the top speed.
Just be aware that gearing the bike for outright top speed will compromise it in other areas.
All Mountain Coaching
1,332
980
GB
My chain guide broke pretty early on, got sent a replacement but never put it on. Not dropped a chain yet and done over 1000 miles on it and the drivetrain. Don't think they're really needed.
571K
