Samwise
My Marin alpine trail e2 has a 2.8 rear tyre and was thinking of going down to 2.6 but with the smaller tyre does anyone know if it would it change the geometry of the bike?
The change geometry wise wouldn't really be perceivable. Handling and grip would be more noticeable. The 2.6 would have less rolling resistance and grip in mud as the 2.8 but not as much on harder terrain. You'll have a bit more frame clearance. I can't see it making a massive difference either way. Having the right tyre pressure for the terrain you are riding would be more important.My Marin alpine trail e2 has a 2.8 rear tyre and was thinking of going down to 2.6 but with the smaller tyre does anyone know if it would it change the geometry of the bike?
I'll second that - I did exactly the same thing. I went through several 2.8's before switching, so had got used to how that felt, but definitely felt better with the narrower tyres.On my original Merida e160 dropping from the stock 2.8's (front and rear) to 2.6's made a huge difference. Mainly that the rear tyre didn't feel like the side wall was going to collapse every time you loaded it
Which size CushCore did you order? Pro or plus? I was able to install the CushCore plus in my 29”x2.6 Maxxis Assigia for the rear, but my rims are 35mm wide. It wasn’t easy though.Thanks for all your replies I've gone with a 2.8 again but ordered a cushcore insert so hopefully feel a bit nicer in the corners and last longer then 3 weeks
I went for the plus and yea I'm not looking forward to installing itWhich size CushCore did you order? Pro or plus? I was able to install the CushCore plus in my 29”x2.6 Maxxis Assigia for the rear, but my rims are 35mm wide. It wasn’t easy though.
Nice. You’ll like CushCore plus.How do you find the assagai on the rear? I see alot of people using it as a from tyre but not so many as a rear tyre which made me wonder why as it's a awesome tyre
I have light bikes 40i carbon rims and there is no sidewall squirm or burping with my 2.8’s, (DHRII’S) either. To each his own, but I find 2.8’s much better in all situations. Better traction, more cushion over small trail chatter, roots, rocks and they actually have better rolling resistance over rough terrain because the tire conforms to the ground Better.2.8 works great with arc 40 rims. 2.6 with more narrow rims. Sidewall flex not an issue with arc 40.
Be careful, the Maxxis tyres will stretch if you haul on the sidewalls while installing, especially if you're using Cushcore. My ebike looks comical as we horribly stretched the DHRII when we installed it - it has a 1 cm wobble.I went for the plus and yea I'm not looking forward to installing it
