Answered 11s shifting with 12s derailleur?
jpaulo.emtb
56
28
Portugal
Hi,
Can i setup a 11s drivetrains but use the Shimano Deore RD-M6100 12Speed derailleur instead as 11Speed derailleur?
The 11s derailleur are sould out.
9,281
The derailleur follows the instructions from the shifter, so it will move accordingly. That's good, but...
When I first fitted a 12-speed derailleur I had all sorts of problems with it. It was definitely a different design to all the other speeds I had fitted.
Some questions.
  • Will an 11-speed chain pass through the 12-speed derailleur? I don't know, but I suspect it will not flow well.
  • Is the total horizontal movement of the derailleurs compatible. The 12s has to be at least as large as 11s. May be OK.
  • From memory, the 12-speed jockey wheels are larger diameters than 11-speed and I don't know what impact that may have on clearance with the cassette.
I would have more confidence in buying a 10-speed derailleur. You still need to do some basic checks though. Get the right length mech arm for ex
Gary
Old Tartan Bollocks
10,496
10,702
the internet
12 speed shimano deore derailleurs use a different cable pull ratio to 11 speed shimano deore derailleurs so no they are not interchangable (according to Shimano)..
10 speed deore pull ratio is very close to 11 so a 10 speed deore M4100 mech will work. just not the absolute perfect match.
I'm not sure why Steve has decided to confuse you even more by asking lots of barely relevant questions he doesn't know the answer to.. old age I think ;)
9,281
I was quite clear that I didn't know, but that I wanted to know the answers. Besides, I was nearly correct, but not necessarily for the right reasons! :)
If I only ever posted when I was certifiably 100% guaranteed to be correct, then where's the fun in that? :ROFLMAO:
jpaulo.emtb
56
28
Portugal
I think you are right!!! The price diference between the 11s drivetrain and 12s was minimal. So I bought the Deore 12s from the same price of a shimano 11s. I'm very happy with the performance. But now i have to replace the out cable of the derailleur.
552K
