ZTTO asymmetric wheels
Dino24
28
36
Spain
Hello all.
I'm looking for thhe wheelset in the picture. Anyone has any input on them?
My rides are not demanding.
9,980
The spec says they are for Enduro, but the rims are a bit narrow for my taste, 30mm external rim width, whereas the minimum I would go for is 30mm internal (the usual measurement).
They repeat several times the word "lightweight", so be warned!
I'm not an expert on rims, so I'm unsure whether being "asymmetric" is a good thing, a bad thing, or just a thing not normally worthy of comment. Maybe someone else can clear that up?
Dino24
28
36
Spain
1,9kg for the pair and yes the width is narrow but I'm running 2.35 tyres. Maybe I'll give them a try.... maybe not...still thinking about it. Also I've got my new fork a few days back and I haven't istalled it yet as the current front hub is 100-15 instead boost.
Astro66
Golden Boy
May 24, 2024
554
998
Sydney Australia
Asymmetric rims helps if you want to run the same length spokes on both sides of the hub. It centres the hub better.
Those are clincher rims so you cannot run tubeless.
574K
