Will the torque/power of the Bosch Gen 5 increase this year with a software update?
6,854
5,302
That’s what Panasonic used to say about Samsung back 2008.
Now people say “Who’s Panasonic!”
you are comparing apples with pears!! The DJI motor etc is not standalone, it has to get fitted to a bike....meanwhile all the leading/volume brands are already committed to Bosch or Shimano etc. Hence the market share for bikes with the DJI system is very small and until/unless anything other than Amflow or a niche brand decides to adopt it .....it is not a key competitor for Bosch.
DirkWisely
161
170
California
But if it proves to be as good as everybody who has reviewed it has said it is, then it's a future threat. Why would brands stick with an inferior motor/battery when their first competitor to adopt it will eat their lunch?
zizajaun
16
I saw a video from a bike show and the Bosch research engineer said that Bosch had decided that 85Nm was the optimum amount of power for both assistance and mileage. As most of my rides are 30+ miles I tend to agree with him. Whether peer or power pressure will take over who knows.
I think if they don't increase it, they will lose a lot of the market to DJI. Whether that's justified is unclear - the DJI's Boost mode (120 Nm, 1000 W) seems a bit gimmicky, but I could see myself using 100 NM / 800 W while doing laps of enduro trails - sometimes you just want to get up the fire road as fast as possible.
TorAtle
141
134
OSLO
From my cabin there's a 17 km 900 vertical meters trail / descent. Obviously the time getting back would go way down with a DJI, which is a big plus. Same advantage for park rides as already mentioned by others. For this reason alone I will not look at Shimano or Bosch.
Oh and btw, did anyone notice that DJI will output 600 Watts with only 50 Watt rider input? That's 12x assistance, compared to 3.4x (Bosch) and 4x (Shimano). Amazing!
6,854
5,302
As fast as possible is limited by the speed cut off beyond which the motor is doing nothing. Product buyers spending large lumps of cash are always advocates and reviewers have copy to sell.
Reliability, longevity, warranty, service and support, distribution, pricing, all play a part in determining product success and most are medium to long term factors yet to be fully tested.
6,854
5,302
No fireroad climb is difficult and offroad techy climbs are all about grip , control and skill at speeds well below cut off.
Personally I have my enduro bike with Bosch motor tuned at plus 3 in Flow and EMTB mode does everything I need..never use turbo. No way would I want max power at only 50 watt rider torque...May as well just have a throttle!
The other thing that would concern me on the video is how much heat is created with such power outputs. It is not just about derating and fluctuation of output. The components of the motor will be going through repeated heat cycles and that does not bode well for longevity.
zizajaun
16
That's useful info, thanks. I was thinking the Bosch would be basically as good as the Avinox once the update comes through, but the lower assistance ratio and longer charging times make me think the Avinox will still be quite a bit better... unless Bosch will also improve those things at the same time.
zizajaun
16
I've never ridden an ebike, but if you're doing a whole day of laps at, say, Forest of Dean or Bike Park Wales, you'd want to expend as little effort as possible to get to the top. So being able to input 50-150 watts and still get up there pretty quickly seems like it could be handy. Maybe not 12x, but wouldn't a 4-8x ratio be usable?
Or to put it another way, I want to spend less than 1/3 of the effort on each bike park climb compared to an acoustic bike. If I understand the numbers correctly, Bosch wouldn't let me do that.
Suns_PSD
596
514
Austin
I think buying a motor system from a competitor that also produces bikes, is problematic.
But beyond that, ya the DJI appears to be a better package. However, the bike is what is what is most important, and both motor systems are very good and certainly good enough. The Bosch is quieter as well.
DJI also has a poor history of providing support after a few years for their drones, so that might be a consideration as well.
BMP
45
33
Iowa USA
I don't think the Bosch really needs any more power as the Gen 4 climbs very well if you get the pedals spinning.
So true! My youngest daughter's BF just bought a 85nm Rail 7. It's his first assist bike. He was floored to see how well the bike climbed with a good spin at the pedals even in ECO mode.
Binhill1
🍊 Tango Man 🍊
Mar 7, 2019
3,864
6,117
I've never had an ebike so don't really know how much power I need, or how big a battery. But I'm 100kg and do a mix of long mountain days, short blasts around the woods, and black diamond bike park laps. For the first two, I'm not in a huge rush on climbs, so maybe 400 W is plenty. In parks, I want to get to the top ASAP and with as little effort as possible, mostly on fire roads, so 600-800 W might be useful.
Yes go big battery I'm 90 kg . You may cycle a lot further than you think we'll I do. I get 45 miles max 1000m climbing ,just a rough guide for u. My battery 700 and I still would like more.
highpeakrider
701
574
Peak District
We have non-Smart Gen 4 Bosch and we rarely use Turbo, and even then only occasionally for silly steep hill climbing. For 'normal' MTB riding it's just stupid fast. If you need a fast eBike buy one and keep off the trails and stay on the roads where they belong.
On a gen 5 i’ve never used turbo and most riding can be done in tour+, on silly hills the assisted hill start works a treat to reduce the starting torque.
Pedec
46
35
Weyburn,Canada
Rocky Mountain been making a 107nm e-bike since 2022. It totally a different design than other e-bike motors. The crank arms are not part of the motor so pedal strikes are less likely to hurt motor. The actual motor does not see water or dirt from the environment you are riding in. Motor power is very adjustable with nice display that shows lots of extra things. But Nobody seems to talk about it.
Biano44
205
204
Charnwood
Massive Rocky Mountain fan but the aesthetics and the separate drive wheel wouldn’t work for me in the UK winter slop.
Pedec
46
35
Weyburn,Canada
Do you know anybody that rides a Rocky Mountain there. I know in Canada were powerplay bike was developed and tested is like a rainforest and very wet (North Shore BC). Kinda why I thought they designed e-bike for wet conditions. But I have seen some vids from UK and mud can be sticky and just gross. I have the RM Blizzard powerplay and one the reason I bought it hoping motor design would take wet conditions better and has so far 500km. What I really like is motor feel it just very strong, smooth, quiet and natural feeling even in lower power setting. I am only using 50-60% of the power most times. I also own a gasgas yamaha powered e-bike and it been good also but just does not have the same feel as RM.
SandroRiz
38
14
Italy
my dealer say YES... only cx 5, at least 95 maybe more; probabily togheter with the launch of the top-tube display
he says 2026, other people september (Eurobike 2025 is in June, too early for me)
gio_se
26
24
Ancona, Italy
I believe 2026 is too late: considering that the release of bikes with the new Brose Drive3 Peak motor (which has 95Nm) should be imminent, I doubt Bosch wants to take the risk of being overtaken by the only real other German competitor in the ebike motor market (yes, I know there's also TQ, but from what I see, for now, they prefer to stay within the e-light category).
SandroRiz
38
14
Italy
If I were Bosch I would be more worried about the Chinese than the German competitors :)
Boogz83
30
12
Uk
I think Bosch need to fix the issue with the motor bushes falling out of various frames before worrying about increasing power to 100nm!
The issue is happening on various makes of bike with gen 5 and Bosch are absolutely useless and still haven’t provided anyone with a fix!
Shocking service from a brand like Bosch
mrtrinh
23
30
Orange County, CA
My
My buddy who has inside info says may 1 for both software and screen upgrade
Boogz83
30
12
Uk
My
Anyway you could speak with your friend to see if he can get any information as to when there is going to be a fix for the motor mounts/bushes please?
irie
3,243
3,384
Chichester, W.Sussex, UK
But the real question is will (whatever it is) be available in pink and cum [sic] with 3 guaranteed blow-jobs? Can't wait for the verdict, really I can't.
Maybe.
But to be fair, the Levo Gen 4 and Santa Cruz Vala thingies promise interesting stiffies and wallet lightening. 🤔
Plummet
Flash Git
Mar 16, 2023
1,208
1,697
New Zealand
My call is the dji motor hasn't had long enough in the market for long term reliability to be truly assessed.
Buy a bosch or Shimano bike for now and consider a dji for you next bike when it's at revision 2 or 3 is out and the gremlins are worked out if the system.
gio_se
26
24
Ancona, Italy
@Boogz83 Do you have any references regarding this issue? I haven't read anything about it around. Thank you
577K
