Bosch Power More 250W
Spiff
450
269
Earth
PowerMore works alone, ONLY if it is activated in ebike configuration. You can verify it in Kiox or Cell Bosch Flow APP, you go to My Bike-Components-Battery and Powermore should be listed as enabled. If it is not there, it won't work
Joecrow
73
35
Munich Germany
It has to be enabled.
Sounds like they need to RFTM, or you need to go to LBS who knows what they're doing.
I'm at the point of giving up on this, it is very frustrating, Haibike and Bosch both say I can retrofit the PowerMore and just need to have a dealer request a new configuration for the bike. Unfortunately none of my LBS's seem to have the faintest idea of how to do this or, I guess, have much incentive to find out.:mad: It seems crazy that an after market bolt on goody requires the involvement of a dealer only software configuration change!
Why didn't Bosch enable the activation via the Flow app.
Jackware
Fat-tyred Freakazoid
2,185
2,391
Lancashire
I've had the same issue trying to get the power socket enabled. It seems the Bosch agent has to email the manufacturer who then has to request Bosch to change the the settings for your bike on their database, so that next time the agent connects your bike it can be updated.
The time involved by the 3 parties just for a simple issue is ridiculous.
Il Canone
Belgium, Beveren
Powermore 250 on Radon Deft – Not Working
Hi everyone,
I tested the Powermore 250 on my Radon Deft today, but unfortunately, it didn’t work. The bike gives an error message saying the power extender is not compatible, even though the app recognizes it and shows a green check as if everything is fine. However, when connected, the lights on the control unit turn red (alarm). Disconnecting and restarting clears the issue, but only without the extender.
To test further, I removed the original 750Wh Powertube and connected only the extender. Unfortunately, this resulted in the same failure. It would have been great to ride with just the extender to save weight, but no luck—it simply doesn’t work.
I’ve sent an email to Radon about this and am now waiting for their response. Maybe they can reach out to Bosch to include this in a future update (I shared my serial number). I don’t know.
I get that the Radon Deft is designed for hardcore (downhill) e-bike riding, and it might not be ideal to attach an external battery with just two screws. That’s probably why Radon disabled the function. Still, I also use the bike for trekking and longer trips, where extra power would be really useful. So I hope they can and want to fix this.
Another issue is that the Powermore 250 doesn’t fit inside the frame. The Deft comes with the high-performance Fox Float X2 Factory rear shock, which takes up some space. Maybe the Orbea adapter (mentioned above) could solve this problem.
Keep you updated.
Iacari
Lisbon
Here is my experience with Bosch smart system and second battery;
August last year bought a new bike with smart system, assembled mid 2022. Also ordered a powermore, a 400wh battery and a short connecting cable to the bike charging port.
After update the bike system with Bosch Flow app I tried to connect the powermore battery.
Bosch gave me a critical error because powermore was not enabled. So I tried the 400wh battery, another critical error since the additional battery firmware was not updated.
The solution was to remove main battery, connect additional 400wh battery again and update its firmware with flow app.
After that install main battery again and, miracle, all green. The system recognized and work ok with both batteries.
So, powermore needs to be enabled but second battery does not.
Back to the bike Dealer, he could not enable powermore with Bosch Dealer software.
But using the Bosh software he started a "Bill" to the bike local distributer that sent him a code and finally the Dealer was able to fix the powermore.
After an update to the powermore firmware all was finally working.
Today, after some experiences with my bike and Bosh smart system, other batteries and cables, some made by my self, I understand a bit better what is going on.
Regards
Joecrow
73
35
Munich Germany
The time involved by the 3 party's just for a simple issue is ridiculous.
I am finally making some progress. I raised a support ticket with Bosch explaning the situation and requesting firstly can any certified Bosch dealer raise a configuration change request (i.e. not necessarily a dealer of the make of the bike), Answer- Yes. Secondly I requested a step by step instruction for making the request, which they provided. I passed that on to my friendly LBS (as opposed to the unfriendly LBS of my bike manufacturer) yesterday 30-Jan and they were able to raise the request without problem and have a confirmation number for it.:)
We now await a response, I'll keep you posted.
Jackware
2,185
2,391
Lancashire
Can you share the step by step guide, in a new thread?
Joecrow
73
35
Munich Germany
Well we finally got a reply from Bosch instructing the dealer to contact the bike manufacturer and forward an enclosed transaction number to process the configuration change.:rolleyes: As my friendly LBS is not a dealer of my bikes manufacturer I have sent the message as a further ticket on the same subject. I await the respnse.
P.S. @Jackware I will update the step by step instructions as and when the process is complete (if ever:whistle::cry:)
fkuzma
Slovakia
Regards
Hi, how did you connect and attached second battery? Also did you try to connect compacttube 400wh with powermore cable? I want to add to my 2022 mondraker second battery but still not sure what is the best way to do it.
Iacari
Lisbon
The problem with compact 400wh is to attache it to the frame.
Powermore cable is not compatible with it, so If you use bosch supports, you need to use battery cables.
I made 2 cables ( 2 different solutions ) and an aluminum support for the standard bottles support.
The easiest cable can be made using one battery cable and a powermore cable.
Cut them to the size and crimp or solder the cables.
You will have a cable with a battery connector and a powermore connector, the small one that goes to the frame charging port.
Now, since this mixes two different cables you have to cross the yellow and green cables.
Red to red, black to black, green to yellow and yellow to green.
The second solution is more complicated because it involves non bosch connectors but it allows to connect the second battery directly to the motor, avoiding long cables and, additionally, charge the two batteries at the same time.
And you can also use it for the powermore.
It is also possible to make a parallel cable to charge 2 batteries at the same time.
Just remember to cross yellow and green cables when you use different bosch connectors.
20250321_102059.jpg 20250321_102130.jpg 20250321_102309.jpg 20250218_222119.jpg
576K
