My first ebike - Focus Sam² 6.9
Gustas
Lithuania
Hey guys, just wanted to share with you my very first ebike, the Focus sam², got it used with 900km on the clock, absolutely love it so far, already have ordered some bling parts for it 😉
Gustas
Lithuania
Looks great is that light hooked up to you bike battery? Also did you change your rear coil. cheers Danski.
You're right, the battery is hooked up straight to the low power port on the motor, i control it through the ebike remote. I had to change the coil, as the one that came with the bike wasnt hard enough 🙂
Danski
Karratha
Nice work on the light what brand is it. Also how did you work out what coil you required. I have been looking for Focus riders' forums on weight to gauge coils and have found nothing. Or did you use coil calculator, and it was correct.
Gustas
Lithuania
Its this one: LS 990 Lighthammer Pro 250 E-bike Headlight
As for the coil, i have a few different rate springs at home, so tested all of them and rode what felt good 😄 i like running suspension on the stiffer side, what's interesting, is that the coil i have on (650lb) measures at right around 23-25% sag (i weight 95kg /w gear)
579K
