Why does my new chain look stretched?
TommyC
294
218
Hampshire
So just been talking it through with the seller on eBay. Adamant it’s all genuine Shimano and I’ve no reason not to believe him. All looks legit. Tried a spare m6100 chain I keep for my emtb (picture is from analogue bike) and the same thing so likely the cassette.
Seller is going to exchange for a 7100 cassette as no 6100 left so we’ll see.
ebsocalmtb
246
272
Southern-Cal
Check the chain with an idiot proof chain gauge, my preference is the pedro's one. Make sure your B-tension is set properly and that your chain is cut to the proper length. There is a lot of counterfit shimano stuff on the market right now... I would not buy through ebay in the future as the counterfit risk is too high.
TommyC
294
218
Hampshire
I fail to see how a b-tension screw or number of links in a chain going to affect this? Here’s another pic. It’s out over the span of 10 or so links. Same with spare chain I had that I bought from my lbs.
wenna
209
144
Sweden
Long time since I had a shimano drivetrain, but is it narrow wide? Maybe you just need to move the chain forward one cog?
6,847
5,292
There’s only an arrow on the quick link but I’ve always put chains on with writing facing outwards. Or is that just some bs I dreamt up?
yes....chain link markings facing ouwards and the right way up on the top loop of the chain. The OPs chain looks to be upside down to me.
9,991
Measure the distance between chain pins to measure stretch, at 12" centre to centre on a new chain it should be exactly 12".
I agree, but not 12" +/- half of 1/16", not even just a bit past the black line on the tape. It should be spot on.
To measure accurately a 12" length of chain, you really need two people. One to hold one of the key indicators (like an inch marker) exactly over then centre of a pin. The second to keep the chain taut and to look at where the exact centre of their pin is in relation to the inch marker. You don't have to be limited by the intervals on the steel rule (usually 1/16"). You can estimate for yourself easily one quarter of that gap, ie 1/64".
Even if both people are out by 1/64" (which I doubt), the worst it could be is an error of 1/32". That is near as makes no difference one quarter of one percent. Accuracy would be tripled if you measured over 36".
I measure over 100 links (50"). Accuracy is one sixteenth of 1%. (Or one twelfth of the 0.75% before reject time).
TommyC
294
218
Hampshire
So I pulled the other bike today with the same cassette and chain and the same thing. This still has the original cassette on it so 100% legit. Tried 3 identical chains, 2 new including one bought from 99 bikes, all the same.
We sure it’s not meant to be like this?
Done 500 miles on this cassette and never had any issue. Works perfectly
6,847
5,292
I dont know if the picture of the chain on the Shimano website is typical of every chain manufactured, in terms of how each link is marked and in what order. You can see below the links do indeed vary in terms of the writing sometimes being the right way up and sometimes upside down.
Tepi
76
33
Finland
Joten vedin tänään toisen pyörän samalla kasetilla ja ketjulla ja samalla asialla. Tässä on edelleen alkuperäinen kasetti, joten se on 100% laillinen. Kokeiltu 3 identtistä ketjua, 2 uutta, joista yksi ostettu 99 pyörästä, kaikki samat.
Olemmeko varmoja, ettei sen ole tarkoitus olla näin?
Tällä kasetilla ajettu 500 mailia, eikä koskaan ollut mitään ongelmia. Toimii täydellisesti
Ketju venynyt paljon, kasetin hammastus lähes uusi.Eli ketju ei pääse pohjaan alaosan kuvassa,se on kulunut rulla osineen väljäksi.Eli hammaspyörän pohja kouru ei saa näkyä ketjun alta.
TommyC
294
218
Hampshire
Question, how does the chain fit onthe rest of the cassette sprockets??? Is it still to big or does it lay on the teeth correctly?
It was still off. I’ve got the replacement slx cassette and it still seems a little loose with a slack chain around it. But when it’s all fitted to the bike and set up it works a treat
576K
