Can you replace a 35mm bar with a 31.8?
force11111
13
Ocala, FL
As the title says. I have a turbo levo and the specs say it’s a 35mm diameter bar. I want to get a bar with slightly more rise but All the bars I’m looking at are 31.8mm. I don’t suppose that would be a direct replacement or do I have to replace the stem as well?
If that’s not doable does anyone have a link to a good 35mm riser bar/brand?
Montana St Alum
257
208
Park City Utah
There are adapters, or you could get a new stem. If you haven't gotten bars yet, OneUp makes nice compliant bars that are a good value. I'd just get a new stem, though if you really need a 31.8, particularly if you need to get more rise than available in a bar.
Polar
Burgtec ride high 50mm
KnollyBro
1,039
2,412
Vancouver
Sorry. I’m the noobiest noob in noobville. What do you mean Maxed on spacers? On the stem?
Why did you want change the rise of your bars in the first place? Spacers (shown in RED) adjust the placement/height of the stem which holds the bars on the steer tube. You may have extra spacers above the stem (you always need at least one spacer above the stem) which could be placed under the stem to get a little more height if that is what you are looking for.
If you are feeling too much pressure on your wrists maybe a bike fitting is a good idea as putting bars with TOO much rise can be difficult to ride.
Montana St Alum
257
208
Park City Utah
Under the stem, on the part of the fork that comes up through the bike, there are circular spacers that can be used to raise or lower the level of the stem. That way you can adjust the height of the stem/bars just by adding or removing those spacers without changing anything else out.
force11111
13
Ocala, FL
It looks like there’s a spacer above the stem on my bike. So I guess I can still move it up
KnollyBro
1,039
2,412
Vancouver
Probably not. You need at least one spacer above the stem. You might be able to buy two 5mm spacers and split the difference as long as there is still enough distance for the steer tube bolt to press down on the spacer on top of the stem.
@force11111, I've replaced stems and bars on my ebikes a few times. While you can adjust stem height by using different spacers above and below (the stem) to your personal preference, always make sure to leave a ~3mm gap between top of steering tube and top cap.
It is also recommended to have a 5mm spacer above the stem and not to exceed ~50mm of spacers below the stem.
Take a look at the photo below. It should look like this.
Montana St Alum
257
208
Park City Utah
Yep!
hilbil-E-bikr
36
10
Alabama USA
I used these last year to install a set of Renthal 31.8 bars I already had on my 35mm stem to get more rise. It was only going to be temporary but really like the way the bars ride so have left them on. I haven’t had any issues. YMMV
SGS
99
131
Sydney
FUNN make a stem that will give you 10mm rise and it's available in various lengths as well. Look for FUNN Equalizer.
Chairman
222
123
Nz
Or you can fit some triple clamp forks which enable you to lower and raise the front end at will.
571K
