General Bits for the Vitus E-Mythique :
Fork Offset : 44mm (1.5" to 1-1/8" tapered)
Shock Size 205 * 65mm (Trunnion)
Link to Rear Shock on VR/VRS
Bottom Shock hardware : 25 * 8mm (Fox code : 803-03-328 DVO code : 1429250-8 Both should be interchangable)
Headtube : 44-56mm Tapered Semi-Integrated
Headset : ZS44/28.6 - ZS56/40
Hanger : SRAM UDH
Rear Hub : 148 * 12mm
Rear Axle : 181mm Length, 14.5mm Thread Length, M12xP1.0 Thread Pitch
Seat Post 31.6mm , clamp 34.9mm
Frame Bearings : 4 x 6901-2RS, 8 x 6802V-2RS, 2 x 6902-2RS
Chainring locknut tool for the M510 in the E-mythique is the Park Tool BBT-18 or equivalent like a Super B TB-1069. The same as the Brose/Bosch 8 notch lockring tool.
For the motor, there is an M510 thread here, but the newer controller (FC2.0) only really starts from Page 53 - the other 52 pages don't actually contain anything relevant or useful. At date of writing the thread was on page 58 and there's not really anything there to be learnt which would be beneficial to anyone with a Mythique.
www.emtbforums.com
If you do update your Mythique firmware to an alternative, in theory you can't revert back - only a Vitus dealer could do that for you. (Firmware is attached in post #12 so you could also flash it with besst)
The C245 Display and the switch both need a 2.5mm hex to remove/adjust.
VR Model with Microshift. Default Chain is KMC X10 - 116 links.
Can also use 11 and 12 speed chains. Presently running an SRAM PC1130 120 link chain with 4 links removed.
Alternate cranks, aliexpress (152's) or Miranda Delta LS, for example 160 and 155's :
mirandabikestore.com
Touch up paint for all the bikes are available here :
Separate Mudguard thread :
www.emtbforums.com
Fork and Shock thread :
www.emtbforums.com
Attachment - M510 Motor manual (install) pdf
Hanger : SRAM UDH
Bafang m510
Thaeber, could be they dont even support now rev i with boot code 0x90 :( What I recon - to sell your motor and buy FC2.0. Anyway, is strange that I see in 43V bin file boot code 0x72 - bafang is messing it quite good. ;) Maybe they have plans not to allow mix voltage. If you buy 43V motor...
Delta LS Cranks 160 Q:16 RF Baf Cold-forged aluminium alloy Standard (Black) for E-BIKE
What's included: Right and left crank arms, installation bolts
Delta LS Cranks 155 Q:16 RF Baf Cold-forged aluminium alloy Standard (Black) for E-BIKE
VITUS BIKES TOUCH UP PAINT - BY GPAINTBIKES
Vitus Bikes bespoke touch up paints, an ideal solution to repair chipped, scratched and damaged paint work on the cycle. Great addition to your bicycle maintenance schedule.
gpaintbikes-colourmatch.co.uk
E-Mythique Mud Guards (+the other Vitus and maybe most none fixed rear triangle bikes)
Depending where you are in the world, the moist season is nearing ... (or ending....) If you have a fixed rear triangle bike, mudguard options are normally fairly easy. You can mount on the seat stays, make sure it extends down to the chain stays, everything's moving in unison and your...
Vitus E-Mythique Fork and Shock Options
It's early days, but it's a relevant subject and will be lost in the main thread otherwise. The bike's well built, capable, has all the right numbers and dimensions and should be a total all round mega machine. Shock spec is 205*65 Trunion. There's not really many options out there in the...
