Battery % data field
Johniboy73
11
Leeds
I saw I video where someone had the battery percentage on their wahoo head unit. Anyone know if the same is available as a single data field from garmin connect?
StuR
449
731
Forest of Dean
Not sure about the Garmin connect app but it can be done on most Garmin devices
Select a fake channel on mission control app. Add that field on your garmin main screen .Sync and your sorted.
I use cadence and its fine . Tried it on BPM - Field goes blank below 30%
My Garmin is an edge 820
Theolegit
147
126
Halstead
I would probably say your Ebike needs to supply an ant+ and/or Bluetooth signal, then it should work fine with your garmin as StuR has said, I’ve a levo which has a dedicated data field via iq for certain garmin but doesn’t work with all, I’ve ok with my fenix 5/edge 1000 but not my vivoactive 3.
Johniboy73
11
Leeds
Have sussed it. You can select the app as just a small data field as per photo here and it just gives you a percentage field. That’s what I was after. Found it by mistake. Percentage more useful
579K
