Fuel EXe Are stiff cranks normal on TQ motor?
PabloNZ
30
20
Wellington, New Zealand
I picked up a new Fuel exe a couple of weeks ago and after coming from a 2017 Turbo Levo FSR there's not much I miss but one thing that in my ignorance is unsettling me.
The issue is that the cranks are quite stiff compared to all the bikes I've ever ridden before. If i kick a pedal extremely hard it *might* spin 360 degrees but in general use I can't easily just bump the pedal to reset the position ready for me to go again.
It doesn't seem to exhibit any resistance when riding but it'd be great to know if it's typical of the TQ motor and nothing to worry about, or something I need to investigate further.
Cheers in advance.
Emailsucks98
377
451
Bellingham Wa
I can't say I've noticed that on mine, feels pretty normal while riding. Have you tried removing the chain, or just dropping the chain off the chainring, to see if the resistance is coming from the motor vs the rear hub or derailleur?
Julie_X1
141
116
Canada
I think you may want to have your bike looked at, I haven’t noticed anything different on my Trek Fuel EXe versus my other bikes…
PabloNZ
30
20
It's not stiff when in use but when I spin the cranks backwards to reset my pedal position. There's a squeak like it's from a seal as well that might just be normal for the TQ motor, or not. *shrug*
Bestak CZ
8
Czechia
Hello, I would try dripping some silicone oil or lube on the crank shaft where it goes into the motor. The resistance and sound is probably created by the simering rubbing against the crank axis. I had the same problem and this solved it.
KevinNY
62
87
NYC
The squeaking you hear is not normal. Is something rubbing the cranks?
However, the speed at which you can backpedal is perfectly normal. Mine is the same way, the crank will not backpedal as freely as a non-e-bike with a normal bottom bracket. If it helps, I have both the 2023 Fuel EXe and the 2023 Fuel EX. The non-e-bike Fuel EX backpedals so freely that I hit my shin (ouch) once when I switched between bikes because I got used to the slower back pedal of the Fuel EXe.
576K
