Levo Gen 3 Fox 36 Rhythm swap
.zig
41
17
Central Florida
My turbo levo was spec’d with a fox 36 rhythm, and I have a pike Ultimate 2022 model which is a sweet ride, at 35 mm. (E-Bike compliant)
Thinking of swapping it over to the levo, and wondering if I will regret it. Anyone else tried that?
.zig
41
17
Central Florida
I don't know your weight and riding style, but...
If it's a direct fit, why not give it a try. You go for a ride on familiar trails and choose the one that feels better to you.
Ya, thought about that, don't have a bearing puller, shop charge, down time, etc. May be worth it. Just don't want to damage the dog gone thing. (slacker ht angle, +- 20 lbs heavier E-bike) Cost a coin to begin with and does a bang up job on my HT.
irie
3,179
3,301
Chichester, W.Sussex, UK
I have a '21 Pike Ultimate on my '22 Trek Rail. I fitted the C1 Debonair Air Spring upgrade to increase the travel from 150mm to 160mm for the Rail (was previously on my '21 Fuel EX), and to improve travel. Really nice fork.
militantmandy
399
369
Tweed Valley, Scotland
Why would you need a bearing puller? Fork swap should be a very easy at home job. I wouldn't worry about damaging it at all, unless you are absolutely enormous.
.zig
41
17
Central Florida
The bottom steerer tube bearing on my SC Chameleon is a pressfit. I know I could use a screwdriver, but I’m not gonna go that route.
I’m about 93 kg so not enormous. I’m pretty sure you’re right about not damaging the fork.
I swapped out the original Recon that was spec’d on the bike, and put this new Pike on there, so I’m familiar with the job. My LBS had the bearing swapped out in five minutes.
.zig
41
17
Central Florida
I think it have split crown race, so switch is easy.
Yeah the split crown ra
OK, cool that’s what I’m gonna do with this one. It was originally at 140, I bumped it to 150, and now when I put it on the levo I’m gonna make it a 160 with another new debonair spring.
militantmandy
399
369
I'm really confused. Why would you need to remove the headset? Just take one fork out and replace the other. They will have the same diameter steerer. The only thing you'll need to swap is crown race, but that can be easily removed with a screwdriver. If it's not split just split it with a saw and install on new fork. Jobs done. Unless I have totally misunderstood, in which case I am sorry!
.zig
41
17
Central Florida
The Pike is currently on my Santa Cruz Chameleon Hardtail which weighs about 32 pounds. My original concern was the Turbo Levo at close to 50 pounds and a slightly slacker HTA would over stress this thing due to the extra weight. My LBS is 10 minutes down the road, so I think I’ll just let them take my crown race off to replace it with the race on the fox rhythm which was Spec’d for the levo. Sorry for the confusion
irie
3,179
3,301
I'm 80kg so perhaps 83kg ready to ride. When I installed the new C1 160mm air spring I was surprised to find that to get about 30% sag I only had to put in about 60psi - prior to installing the new air spring I needed about 85psi!
I even called TF Tuned (who I bought the Pike from) to check and they said they weren't surprised.
.zig
41
17
Central Florida
I was gonna mention that too. I originally had about 90+- psi, for 27+- sag,in the original 140 (before changing the spring) now down to 60 as well, to get 27%. That's with the 150 conversion. 'nother thing... I contacted Sram support about the Maxima plus fluids they recommend. The guy said he tried them after being a skeptic like I (was). Let me tell you, 5mm of the heavy in positive side, 10mm lite in the negative side, and the stiction went way down. Really made a difference IMO
kimochi
48
17
California
You mean overstress the pike? Don’t worry about it man those forks are overbuilt.
irie
3,179
3,301
Ya, That’s what I’m thinking
No problem, see below. For my Pike Ultimate serial number Rockshox says "E-BIKE APPROVED".
Pauliemon
211
310
Northern California, USA
Bottom race with a screwdriver no problem. Just use a small flat blade and a plastic hammer. Lightly tape all the way around until you get a edge.
I didn't care much for the Rhythm. I bought a Fox 38 because I didn't have a nice Rock Shox lying around. That fork will rock that bike.
.zig
41
17
Central Florida
I’m gonna check it out tomorrow. Can always switch back if it feels too loose. Not much downhill in this area . Thanks for the input.
Pauliemon
211
310
I have to confess I never rode with the Rhythm 36. My SL came with a Rhythm 34. I put some time on the 34. I didn't like the small bump compliance on the Rhythm. That's something that Rock Shox excels at. That's something you want coming into those fast sweepers.
571K
