Worth upgrading - OEM fox 36 rhythm to a Fox 36 factory float
2WheelsNot4
924
713
Obviously a different damper - grip 2, but no lockout to my knowledge, not that I think thats going to bother me.
OK its black and orange and its Kashmir. But anything other ?.
Mteam
1,936
1,884
gone
The factory 36 is 4 way adjustable, hsc,LSC,HSR,lsr
If you've felt that your current fork needs adjustment in one of those areas but you can't because it doesn't have the adjusters, then it might be worth it, otherwise I'd say not worth it for you.
But if you just want it because it's shiny and gold then that's also fine.
2WheelsNot4
924
713
I didnt win it. My last bid was £617, sold for £627.01.
Timochka69
144
103
Helsinki
Well, you could also upgrade the 36 Rhythm damper to Grip 2 for much less money and maybe convert to coil using Marzocchi Z1 parts. You would end up with better working fork, but a bit heavier than the Factory one (and not shiny).
I converted my 36 Rhythm to coil, still using the Grip damper, which is OK for me really.
Endoguru
142
131
Usa
Agree with Timochka69. Grip 2 damper upgrade is much cheaper. The Rhythm fork is slightly heavier than the Factory fork. I doubt you would notice on an ebike. In the past Fox has stated the Grip 2 damper does not fit in the Rhythm fork, but it does. I’ve done it with no issues.
randycpu
116
51
Silicon Valley, USA
Google "snipe"
Stoffel
121
201
Cotswolds UK
2WheelsNot4
924
713
Google "snipe"
Im not into that. It could go wrong, or i could set it up wrong. I prefer the submit bid in the last 4 seconds strategy. The bottom line on this is i should have made my final bid higher.
As I would be selling the stock fork on the bike, probably for £350, I should have bid about 700 Teh grip 2 is just over 400, so all in all other parts considered, stanchion coating, the lower leg bypass ,different crown, and the damper, it would make more sense to change the entire thing.
Basically I was an idiot. I needed a 260mm steerer and those arent readily available unless its like the tri sport auctions of 'new other' Lesson learned, ill just bit far higher next time.
577K
