the weld on the chainstay just behind that also looks suspect.Cheers
very helpful
Just checked mine it has a hairline crack in the same area
FFS .
very helpful
FFS .
I really hope all this is sorted on the 2022 model
This is a forum where we can learn. Many here are doing their research on what to buy. The rise in particular is pretty expensive, even for an emtb. At the least I think this is a pretty good "heads up" if you're in the market for a new bike. More so when you consider what looks like another issue unique with the orbea rise - losing battery charge while the charger is still plugged in but not charging (orbea charger and battery).I have already bought one as have others so without being rude it really doesnt matter if you would or wouldnt buy one
yup deffo cracked there toothe weld on the chainstay just behind that also looks suspect.
Again I hope they have sorted the stays on the 2022 model as they claim to have fixed the other issues.The alloy chainstays commonly crack on the Orbea Wild frames, so much so that Orbea sends you a free carbon upgrade if it does.
And when you compare the alloy version to the carbon version it's easy to see why.
The carbon chainstay is so much beefier and stronger looking in the exact spot the alloy ones crack. Almost makes me wonder why Orbea continues to use the alloy ones without a redesign.
But with that said Orbea seems to be warranting all of them so they are standing behind the product.
My Rise (carbon) takes an absolute battering and is absolutely fine. Remember, the Rise and Wild are different frame designs and have significant weight difference...We’ve been looking at a Rise for my other half, this certainly doesn’t give me much confidence in their frames![]()
Looks extremely familiar. Should be hearing from Orbea in a few days. 3 weeks into the warranty process.
I purchased through Jensonusa and went through Jensonusa for the warranty. Jensonusa is in contact with Orbea and said Orbea will contact us in the next few days. I started the warranty process 3 weeks ago.Sorry are you saying that you haven't heard from Orbea in 3 weeks in regards to your warranty?
That's awesome! At the time no lbs had any bikes in stock. I always try to shop local for sure!I hate to say it but that's why I always suggest people support their local dealers. The warranty procedure with Orbea is really easy, they have basically a live chat directly with Orbea. I had my RMA within 3 days from Orbea.
The Wild FS H20Which frame have you had trouble with ?
The Wild FS H20
I'm hoping to get the carbon upgrade!It looks like it's only the alloy frames and rear triangles with issues. After receiving my carbon replacement frame and directly comparing it to my alloy frame it's easy to see why. That carbon frames have a much stronger and beefier construction in the the spots where the alloy frames are failing.
I look forward to snapping my second frame and then maybe getting that upgrade.I'm hoping to get the carbon upgrade!
I hope it doesn't come to that!I look forward to snapping my second frame and then maybe getting that upgrade.
Good for you, I still wish I had been offered a carbon upgradeThis is what orbea wants to send. Jensonusa is making sure my components are compatible with this frame.
Only one i heard about was less shock clearance on the carbon vs alloy versions.I believe that's the same 2022 frame they will be sending to me. No issues with the 2021 components fitting in the 2022 frame?
Good for you, I still wish I had been offered a carbon upgrade![]()
Yeah I did have my mechanic ask, but was denied.
