Uneven pad wear
Woodyboy
71
251
Uk
Keen on anyones thoughts please, my rear brakes didn’t feel right on my last ride. Grippy bit rough. I took the pads out (100 miles old) and they appear shiny but not across all the pad. Do they just need sanding and bedding in again? Never had this issue before.
Brakes MT7 pads gorilla
VWsurfbum
🤴King of Bling🌠
Jan 11, 2021
1,623
2,412
England
unusual for sure, like its not sitting flush?
could try resetting the caliper?are all 4 pads looking like this? if so a loose caliper/frame mount?
Woodyboy
71
251
Uk
Cheers, I’ll check for any play. All 4 pads similar.
VWsurfbum
🤴King of Bling🌠
Jan 11, 2021
1,623
2,412
England
I know theory doesnt come into MTB very often, but the pads should always be completely flat against the disc when they touch, so uneven wear "shouldnt" happen?
Gary
Old Tartan Bollocks
10,496
10,717
the internet
If that horizontal wear line is across the braking material at the same height on your inboard and outboard pads your caliper probably isn't spaced properly (incorrect mount) or you're not running the correct rotors. Either way it looks like the pads aren't sat correctly on your rotors brake track.
578K
