Compression Ratio for Fox X2 Shock (160mm)
Rich-EMTB-UK
369
284
Hi,
Does anyone know what the compression ratio is likely to be for the Fox X2 Factory rear shock on a Yeti 160e T1 build. I ask as I cannot manage to get the shock to anything like fully open when trying to set this on my shock wiz. Having deflated the shock it collapses and is compressed and nye on impossible to move more that 50 mm (2 inches).
for now I have guessed at 2.1 :)
TIA
Rich
Mteam
1,936
1,888
gone
2022 Yeti 160E Review - Mountain Bikes Feature Stories - Vital MTB
leverage graph is about half way down the page.
There is still probably air in the shock, remove the valve core and try to compress it
Mteam
1,936
1,888
gone
Hi, it compressed it just won't pull to it full extended position.
ah right - you've got too much pressure in the negative chamber in that case, probably from letting the air out of the main chamber too quickly and not letting the air flow from the negative chamber while the valve was open .
Pump it back up to normal pressure or higher until you get full extension (dont exceed the max pressure for the shock though) and let the air out very very slowly holding the shock at full extension, as the air chamber empties, every 10 psi of pressure loss cycle the shock slowly past the sag point this should equalise the neg chamber as you deflate the shock .
Rich-EMTB-UK
369
284
ok, will give that a try - Many Thanks
apac
1,326
1,173
S.Wales
I found that letting the air out using a shock pump left air on the negative chamber. Use the shrader cable direct… carefully and slowly got all the air out. The X2 needs lots of fine tuning to get the most out of it. It took me months.
579K
