Brake rotor upgrade
Vfour800
51
31
Brackley Northamptonshire
Hi All,
I would like to upgrade my Shimano rear rotor from a 180mm to a 203mm.
I have attached images of current setup
Does anyone know the bracket and disk that I need please?
Cheers
Mark
vext
70
40
Los Angeles
Hi All,
Cheers
Mark
Figure out your frame's default size. Likely it fits a 160mm by default (no riser). So look for a shimano 203 riser bracket that works on a 160 default (once you confirm the 160 actualy is the default)
Any 203 will work but pick one thats robust unless (AKA not alloy sandwich)
577K
