Kenevo Gen1 Kenevo expert rear suspension options
Cseven
61
42
Seattle
I’m looking to change my 2021 Kenevo experts rear rockshox air shock with either a coil or a float x2. Would anyone have recommendations of either or? Also would anyone know the correct specs of the coil shock I would need?
Thank you for your input!
Pic added for fun
Alexbn921
545
513
East Bay CA
230x65mm.
I'm setting mine up to use the stock 62.5mm and only use the last 2.5mm if I do something wrong. Buffer instead of bottom out and the frame has plenty of clearance at 65mm stroke.
Clearance is tight to the side brace on my S5
CruJones
47
13
230x65mm.
How do you like the X2 from your prior shock? I have a '21 Kenevo Comp and find that the lack of adjustability (I have Performance DPX2)on the OEM shock is starting to become a bit annoying. I want more mid-end stroke firmness and the DPX2 is already maxed out (from Specialized) with volume spacers.
576K
