Hello from new member. Just brought a Haibike ALLMTN 7
Streaky
8
Norwich
Hello. Just brought my first emtb a Haibike ALLMTN 7 anything I need to know about it?? Seen some issues with chain rings and chain suck.....
Streaky
8
Norwich
??‍♂️? ok. Do you own a ALLMTN 7? Anyone tried a Velcro strip on the back off the battery and the back of the cover rather then a strap all the way around the bottom tube??
pampmyride
125
161
Sussex Massif
I've had one for 3 weeks...So set -up ... go tubeless. Check shimano split link to see if tight fit on front sprocket/chainwheel. If so, change for a Sram one, it has more room. Get to know the clutch setting on the derailleur. Maybe get one of those neoprene frame socks - keeps gunge off the front & away from battery area. Get mudguards... I need a rear!
Shinn
375
277
Decorah, IA USA
Streaky
8
Norwich
Cool. Thanks for the heads up! You talking about the chain? Change the chain to a sram??
Streaky
8
Norwich
Yeah. don't wash it too intensely.. That kills ebikes ... or if you do . Go easy no pressure. Oh and de restricted is much better . Maybe u need a white skull sticker or a skeleton fish .
You de restricted yours?? I don’t want to void the warranty? I have been reading about it tho. Vol speed and speed box seem to be the front runners...
578K
