Bosch sprocket issue
Sander23
740
458
Belgium
So I changed my 11 so XT drivetrain to sram ex1 and now my chain touches the motor.
A while ago I had tried 21t kmc sprocket with E-chainguard but I had to much chaindrops on the front sprocket. Then I switched to this sprocket and problem was solved
How can I fix it so the chain won't touch the motor?
Sander23
740
458
Belgium
I thought it was the sound off rubbing the chain against the motor but I put a small alluminum ring bestween the motor and the sprocket. Bit the sound is still there.
Sander23
740
458
Belgium
Without sounding like a nut , can you put it on backwards , upside down or backwards ... ?
I had the same issue , but my front cog was raised on one side
Offset is probably the best word .
replacement cogs - not Bosch branded are flat .
What do you mean? I need to paddle backwards?( If so I can't do that)
Hahaha , yes , sit on the handlebars !
no , the Bosch rings are offset to counter the boost chain line - I think the haibike don’t run a offset ring .
Although in your message you said you put a spacer ring in ?
Admittedly I ve only ever run the xt durarace chains - I have just bought a kms , so i will have to check it before riding too far
only other q is - are the plastic covers all fitted correctly, , mine filled with mud and was a bit wonky .....
Sander23
740
458
Belgium
This is the original haibike sprocket that came with the bike.
But that's an 16t and I find it to small. The same sprocket goes 18t I believe. The one above that I have now is a 20t and it's perfect for my usage.
I don't have any plastic covers I believe.
Jamze
391
721
Oxfordshire
That does sound like the chain hitting the plastic motor cover.
Just looking at those two chainrings (the original that has a guard on both sides compared with the completely flat 20T one) looks like you've moved it >5mm closer, which will be an issue. I think you'll need more than a small spacer.
Sander23
740
458
Belgium
I installed the original chainring and the sound seems gone after a small test ride.
What options do I have if I want a 20t chainring up front?
The sram ex1 sprocket seems to have up to 18 t but then I have the same problem.
Kmc and connex has only flat chainrings
Jamze
391
721
Oxfordshire
Same issue others have had .
You could measure from the back of the mount plate to the centreline of the chainring teeth on both the original and the 20T, and find a spacer that makes up the difference? Biggest I've seen for Bosch is 2.5mm, and they say only use one ?
Bear-uk
1,005
1,371
Harrogate
I sorted mine with a milk bottle. The new flat basic 14t chainring needed a couple of spacers making.
Sander23
740
458
Belgium
I contacted Miranda they said the original is a 5mm offset. So the only sprocket they have is a 16 t double bash Wich cost 128€.
They do have a 3mm offset 20 and 22t sprocket. Will that be enough if my sprocket now is witouth offset( at least I think it's without)
Bear-uk
1,005
1,371
Harrogate
Edit. My set up allowed for plenty of adjustment before the sprocket did not sit on the splines
576K
