Hope Rotors 2019 Levo
atcspaul
194
216
Portage, Michigan
Has anyone mounted hope rotors themselves? I have read on the forum that the sensor does not clear the frame and modifications had to be made however the shop had done them for the riders that have put them on. If any one has put them on themselves did you need to modify and if so how. Thank you in advance
atcspaul
194
216
Portage, Michigan
Update. I purchased the rotors and they work great, no modifications needed. Have enough clearance to clear magnet so does not rub frame on back wheel
Carnie
7
New Zealand
Update. I purchased the rotors and they work great, no modifications needed. Have enough clearance to clear magnet so does not rub frame on back wheel View attachment 14590
Hi, so you had no issue at all and didn't have to file anything down? Ive got a pair on order for some sram code rsc. I imagine the caliper size would be the same so this is great news and I dont want to go filing anything down.
atcspaul
194
216
Portage, Michigan
no problems at all. you will like them. They work and look great. I ended up buying hope brakes also, not that anything was wrong with the sram/hope set up, I just wanted some bling
Carnie
7
New Zealand
I tried them last night and they work fine front and rear, however the rear rotor sits very close to the carbon caliper mount on the frame. Did you find this as well?
577K
