Decoy Fox Float X2 Setup
Barty_NorthVan
41
41
North Vancouver
Hey Decoy'ers!
So I upgraded to the 2020 Fox Float X2 and was wondering about how the other X2 owners have it set-up.
Anyone make changes or running different settings that are working for the extra weight of the bike?
I found this as a starting reference from Fox:
Recommended Damper Settings
After setting shock air pressure by adjusting sag, use your air pressure in the table below to help find the suggested starting damper settings. As you ride and get used to your new shock, adjust your settings as needed.
Turn all damper settings to the closed position (full clockwise) until they stop. Then back them out (counter-clockwise) tot he number of clicks shown in the table below.
Note: HSR and HSC adjustment is only available on Factory Series FLOAT X2 shocks.
Barty
Fatbap
153
150
Rhondda south wales
My weight is not on that list lol
My settings are
Fox factory forks are at 135psi with 3 tokens 15% sag an rear shock at 325 with 3 tokens 23% sag
Im 125kg ish dropped a little bit of weight
Settings are near the limits an bike feels awesome
Russ2550
33
US
Hey Decoy'ers!
Barty
Hey not exactly same topic but I just bought a new 2020 Fox X2 from Pro’s Closet that did not come with the 4 digit ID number which is making me wonder. Is there anywhere else on the shock that has a serial number?
564K
