Yakima StageTwo + Add-On vs ?
Brad L
I am looking for a 2" hitch rack that has a 2 bike carrying capacity that can be extended into a 4 bike carrier for (rarer) family adventures. Most often I would use the rack in the 2-bike configuration. We have a variety of bikes from ~26kg eMTB, dually MTB, Carbon roadies, through to 24" kids bike.
I've narrowed down my search to the Yakima StageTwo with the StageTwo +2 Add-On (AU$1400) or the Kuat NV Base 2.0 with the NV Base 2.0 X2 Add On (AU$1900).
My biggest concern with the Yakima StageTwo is that it looks difficult/time-consuming to install and uninstall the add-on; almost as if the add-on is designed to permanently live on the base rack. Does anyone have the StageTwo add-on, and how long does it take to install/uninstall the add-on? Do you take the add-on off the base rack? Would you recommend this rack and add-on?
Should I be considering another hitch rack option? (Note, I'm in Australia and 1Up racks don't seem to be an option)
Many thanks for your replies.
R3Z3N
80
62
California
Personally those 3 should be forgotten. Simply because they are too far away from hitch and distance between trays is much too long, creating a huge increase in torque at the hitch. As hitch rating is about 8" from hitch pin, your tongue weight IS NOT A SYSTEM WEIGHT for the rack.
Anyway, take a looksee here but I recommend the 1UP Super/Heavy duty over EVERYTHING else unless you need more than 4 bikes, simply because of the torque at hitch, and this WILL create less grip for your front tires of the vehicle, which I can even feel on my 4x4 full size Lincoln Navigator. I have the 1UP Super duty double and 2 addons as well as Velocirax 6, simply because the 4 bikes is still shorter loaded up compared to the Velocirax.
527K
