TRP brakes with SRAM rotors
Aug 2, 2021
14
7
Western Colorado
I have Code brakes with 200mm SRAM HS 2 rotors (2mm thick) on my Heckler and I plan to swap the brakes for TRP Trail EVO's.
TRP uses 203mm (2.3mm thick) and I'm concerned anout my rotor diameter being off by 3mm.
I do realize that that is only 1.5mm at the edge.
Do any of you have experience with this caliper/rotor combo?
Eager for info!
Thanks for any help.
Gyre
629
420
Pasadena, CA
Eager for info!
Just adding on to @BAMBAMODA 's comment. With respect to the thickness, there should be no issue. I use 2mm rotors on my DHR Evos and the manual only prohibits 1.8mm rotors.
527K
