Suggestions for replacement shock on 2023 scott eride ransom for heavy rider
Rocketb
27
19
This bike came with a performance x2 (comp/rebound) in scott tune.
It started leaking air then the dreaded x2 squelch came.
Fox Australia replaced for a 2024 factory x2.
This lasted 9 days with oil leaking on the reservoir.
Replaced last week with another 2024 factory x2.
I’m running 298psi and two air spacers, feels terrible.
I contacted fox last week and they agreed to replace with a factory float x (350psi).
This bike has 180mm of travel and I do flow/dh and trail Knar type of riding so not sure if this shock will hold up!
I haven’t used a coil before (would need a 708 or larger spring) but open to what works.
Any suggestions?
Rocketb
27
19
Hi
Before you get into coils
Make sure the leverage ratio on the rear suspension is high enough if your jumping etc (y)
Yeah I thought this might be an issue. The Öhlins distributer recommended a coil over air but said it would come down to preference
Paulquattro
1,907
1,041
The Darkside
I fell into this with my trek rail
Loads running coils but for me the suspension wasn't progressive enough so ended up with an ohlins air can (y)
Paulquattro
1,907
1,041
The Darkside
How do you find the shock? I was seriously considering this one.
Brilliant
I had it tuned for the Rail when i bought it and its been faultless
Easy to add and remove tokens too which is good if you like a bit of tuning yourself .
Rocketb
27
19
Surely the new Vivid has to be a contender:
I went through two suspension tuners here and both agreed the shock would be too linear with the larger shaft and air can ie coil like. I agree the shock looks good but my factory x2 was too linear and not progressive enough for my needs.
527K
