Sold Whyte 909 V3 2021 - NEVER USED.
Baileyjd
51
14
Midlands.
Brand new Whyte 909 - never been ridden .
Caught one of the last to land back in December - have proof of purchase
Size large
£2100
Bottle cage and pedals not included.
COLOUR Matt Zinc with Grey & Dark Grey
CASSETTE SRAM XG 1275 Eagle, 10-52, 12 Speed
FRAME 6061 Alloy, Hydro Formed T6 Aluminium, Multi Butted, Custom Drawn, Tapered Headtube, Internal BBX Cable Routing for Dropper Post and 12mm X 148mm Boost Dropouts
CHAIN SRAM GX Eagle, 12 Speed
FORK RockShox Pike Ultimate 27.5", 130mm Travel, 37mm Offset, DebonAir, Charger RT3C Damper, Fast Black Coating, Tapered Steerer, 110mm x 15mm Boost, Maxle Ultimate
CRANKSET SRAM GX Eagle, X-SYNC 2, Direct Mount 32T, DUB, 170mm, Boost 12 Speed
REAR SHOCK N/A BOTTOM BRACKET SRAM DUB, BSA, 73mm
HEADSET FSA No. 57E Orbit ZS, 1 1/2" Lower and 1 1/8" Upper Sealed Cartridge Bearings
SEATPOST KS RAGEi, Dropper Post, 30.9mm, S 125mm Travel, M/L/XL 150mm Travel, Southpaw-Alloy Remote Lever
REAR HUB Alloy, Double Sealed Cartridge Bearings, 12mm x 148mm Boost Through Axle, Micro Engagement 4 Pawl, XD Driver, 32 Hole
SADDLE Whyte Custom, Triple Panel Design
FRONT HUB Alloy, Double Sealed Cartridge Bearings, 15mm x 110mm Boost Through Axle, 32 Hole
HANDLEBAR Whyte 6061 Alloy, 30mm Rise, 31.8mm, 780mm Wide
SPOKES DT Swiss Champion 2.0mm, Black Stainless, Brass Nipples
STEM Whyte Gravity Stem, 35mm Extension
RIMS WTB ST i35 TCS 2.0 System, Pinned Joint, Tubeless Ready, 32 Hole
GRIPS Whyte Lock-on V Grip
TYRE Maxxis High Roller II TR 27.5" x 2.8" 120TPI, EXO Sidewall protection, 3C Maxx Terra, Front, Maxxis Rekon TR 27.5" x 2.8" 60TPI, EXO Sidewall Protection, Rear
BRAKES FRONT SRAM Guide G2 R, 4 Piston, 180mm Disc
SHIFT LEVERS SRAM GX Eagle, MMX, 12 Speed
BRAKES REAR
FRONT MECH N/A BRAKE LEVERS SRAM Guide G2 R, MMX
REAR MECH SRAM GX Eagle, 12 Speed
PEDALS None
Similar threads
529K
