Orbea Rise Range Extender installation and screws torque
PhilS
39
31
My factory alloy bolt sheared at 3nm, luckily it was easy to get out. I replaced them with steel rotor bolts (everyone has a drawer full of those spare!) and added a washer. I went for the full 5nm as instructed due to the weight of the battery.
carlbiker
Sep 15, 2020
1,047
455
leeds england
Can you post a link to these bolts etc? Cheers
PhilS
39
31
It looks like the Shimano part number for them is Y8KT98010, I just have some spares in the cupboard as every time you buy rotors they come with more bolts!
carlbiker
Sep 15, 2020
1,047
455
leeds england
PhilS
39
31
carlbiker
Sep 15, 2020
1,047
455
leeds england
I used some random washers from my toolbox. If you aren't sure or don't have parts around, just install it as Orbea say. If anything happens you will be covered by warranty if done correctly.
Sounds more fun to avoid a warranty issue I think ?
NOS_emtb’r
13
18
Usa
My issue is the fit of the extender In a size small frame. It is such a tight fit, really hard to slide the extender into the battery holder. Any suggestions, don’t want to snap the holder, or yank the bolts out of the frame, therefore damage to the frame☹️
KuRi
376
186
Spain
I think it is always a tight fit. You need to slide the extender laterally with some pressure. Don't be afraid of some holder bending when doing it. You need to insert it diagonally until you are under the rear suspension, then rotate it until parallel. Good luck!
Tubby G
❤️‍🔥 Hot Stuff ❤️‍🔥
Dec 15, 2020
2,630
5,268
North Yorkshire
Yes. And firmly as the plastic clasp is quite stiff.
Thanks. I thought it would to be fair, and the Orbea website states it does. I’ve been chasing my lbs for my range extender as I need the cage to hold a water bottle and I’m reluctant to buy one as I have the range extender coming, but my lbs just told me this morning that the cage won’t fit a standard bottle, hence my question on here!
Hjwemtb
Uk
I have just deformed my alu bolt head and now can’t get it out - arrrrgh! Tried filing a slot for a flat head screw driver but have made it worse.
Any ideas how to get it out?
529K
