Mondraker Crafty R 2023 -Fox 38 Performnce Grip setup
saione
33
19
Lerici
HI guys.
I have Crafty R since 10 days. I'm interested in sharing the fork setup with Grip cartridge. My previous experience is with a Grip2 cartridge and a ZEBB ultimate with RC3.
My weght is 100 Kg
Pressure : 100 psi
Tokens: 4 as per Fox default
Rebound: 5-6 as per Mondraker recomendations
With this setup I can only open the compression setting in the MID position.
If I open completely the compression setting the bike is pitching a lot excpecially in rough and rocky terrains.
Do you think that if I add another token, I will be able to open completely the LSC settings?
Thanks.
Bones
766
1,004
Harrogate
Take the tokens out, there main purpose is to stop the forks from bottoming out. Now try and set your forks up to suit you. If you bottom out on big hits then add one at a time.
527K
