Simonp3
30
8
Denmark
I really need some technical help for my Mavic E-Deemax 30 front wheel
It's on my 2023 Crafty RR.
It has now ridden 400 km, and i have a squeaky front wheel, and there's water coming from inside the bearing.
I usually service all my bikes myself, and it's bought online, so i don't really want to ship it out of country for a wheel bearing that needs regreasing..However, i am having a really hard time getting to the wheel bearing!Took the wheel off.
Took the Endcaps off.
Now i need to get past the washer to be able to access the bearing, however this seems impossible.
I have attached the exploded view of the wheel.
Tried Mavic customer service, which only were able to send me the attached manual..
It seems like the whole hub is pressed together.
I have tried bearing extractors and whatnot.
I have been a licensed car mechanic for years, so i know how to handle tools, but this 10 min simple job seems impossible.
I need to get past the flexible plastic washer (9) i can see the lockring behind the washer.
On the pictures i have removed the endcaps!
434448840_3797352733867781_1179086276771793394_n-jpg.137964
6,181
4,701
no experience with these hubs but since the washer has no pin holes it is probably not threaded in...........so must be a press fit. It may come off a bit like an end cap by inserting a tool which is a reasonably tight fit into the centre and levering it side to side. Otherwise an expanding blind bearing removal tool should do it.
527K
