Swapping fork from Fox34 to 250mm Fox36, but… lower headset bearing seems to have disintegrated after 600miles (poor!) What bearing do I need to replace this, and is there likely to be any of the old bearing left?
thanks, CB
thanks, CB
Ok, remains (outer) of old bearing out. What bearing (code??) do I need to replace? Bike is M20, with Acros bearing. Top beaStupid iPhone with oily fingers!! Lower headset, and 150mm!!
top bearing is fine, and she’ll of old bearing now out.Stupid iPhone with oily fingers!! Lower headset, and 150mm!!
Crunch,Ok, remains (outer) of old bearing out. What bearing (code??) do I need to replace? Bike is M20, with Acros bearing. Top bea
What bearing do I need to replace this?
Piss-poor bearings if they only last 6 months!! not impressed!
Having too much tension on them can also destroy them pretty quick!Will keep a much closer eye on these now!
Have got the Chris King headset in my Rise after my bearings fell apart not been in long for longevity reviewGreat info Rod B!
Anyone have experience with the premium products like chris king? I've gone to Hope levels before and wonder how much better that double the cost gets you?
Great info Rod B!
Cookie,Having too much tension on them can also destroy them pretty quick!
Hi Rod, when you say clean and lube, you mean externally or do you pull them apart and regrease/repack?clean and re-lube the bearings every six months or sooner
Cookie,Hi Rod, when you say clean and lube, you mean externally or do you pull them apart and regrease/repack?
