Is the steerer tube on a Powerplay Instinct tapered?
A06
106
85
Corona, CA
Yes the they are tapered...that is to say the head tube bearings are of different diameters. One could run a smaller bearing on the lower cup for a straight tube fork (Dual Crown) if you were inclined to do so. But the point here is the OEM configuration is for taper HT's.
The HT Bearing specs are also on the RM tech support site if your inclined replace or upgrade when you swap forks.
529K
