Fox 38 Knocking sound
Simonp3
30
8
Denmark
Not headstock bearings loose ?
Nope. Tried tightening the headset like, a lot. Also slightly over tightened the wheel axle. Nothing helped. When I hold my hand on the black outer legs, I can feel the knocking on the inside of the fork.
8,747
Talk to Fox, or whoever you bought the forks from. It is always unwise to ride a bike with a new or odd noise until you have found out what it is. It may be nothing, but it could be something. :unsure: :eek:
Christurbo
380
714
North Wales
If this was me (and its not) I would:-
Remove fork from frame.
-Service headset (or even replace)
-Lower leg service on the shock, torque lower bolts to factory spec
-Refit headset and grease
-refit fork
Ride.... I bet this will fix your issue as it will cover a number of variables.
There is a known issue where the stanchion meet the crown where some forks start to creak (not knock), preventive maintenance for this is to work some Loctite into the seal with fork upside down and wait until it sets. This is what Fox do (but they obviously remove the stanchions to add the Loctite).
Spin
154
201
-refit fork
If this was me , the bike ridden 20kms ? Straight back to the shop!
If it is something internal in the fork , that's clearly poor QA and should not be the buyers problem.
InRustWeTrust
509
730
Sweden
I agree here , if the fork is new it should go back to the shop asap. If you open up the fork maybe the shop denies to give you a new one so dont open it.
wenna
208
141
Sweden
If not the headset or wheel, it sounds like play in the fork bushings to me.
Do you get the same play with the wheel straight and using front brake to rock it forwards and backwards?
Simonp3
30
8
Denmark
I only get play, when I turn the fork 90 degrees. I disassembled the headset and greased it up, I also tried without the brake caliper. It is definitely the fork..
Simonp3
30
8
Denmark
It's not your problem, it's the shop's problem. Do not open the fork, just do as said above, take the fork back to the shop.
Only problem is that I bought it online, so it's quite a hassle, but I have contacted Fox, and the online shop.
irie
2,066
2,017
Chichester, W.Sussex, UK
If you bought it online you will have EU distance selling laws to protect your purchase, also credit card protection. The forks are defective so get a refund and start again. The longer you leave it the potentially messier everything gets.
Simonp3
30
8
Denmark
Yeah, i know. Altough, the fork was on the bike i bought online, so i have contacted both fox, and the dealership.
Christurbo
380
714
North Wales
Agreed to a certain extent but that could be days/weeks off the trail and the advice I gave would take 30 mins.
I always drop the lowers and slightly more as Fox use too much grease which impacts on harshness.
Christurbo
380
714
North Wales
That sounds to me like it could also be the hub brought into the equation that needs to be ruled out.
Put it in a stand. Remove the wheel and get someone to hold the frame whilst you check for play at 90 degrees and check it’s still there with no wheel.
Spin
154
201
Yeah but one thing worse than buying a new bike and not getting to ride it until a warranty issue is corrected is voiding warranty by touching the problem yourself.
Simonp3
30
8
Denmark
So i got a hold of my mates Mondraker Dusk R, also brand new. He's got a Fox 36 Fit4 installed. It does the same thing!
527K
