Brake pad upgrade to increase power
BRAAAAP
England
Hi everyone,
My bike came with SRAM G2 R brakes, and I'm looking for a bit more power. I've increased rotor size and am now looking to get some new pads. I'm leaning towards getting Uberbike E-Matrix pads, but am also considering one of the ceramic compounds from Gorilla brakes, or maybe one from disco brakes. I'm wondering if anyone has any experience of these or if there are any other recommendations.
dobbyhasfriends
🌹Old Bloke 🎸
3,218
4,597
Llandovery, Wales
Ive tried a few different brands and compounds that they offer but the best I've used for noise, stopping power and wear rate are CL VRX pads.. expensive but well worth it.. I was using them and then tried the uberbike Ebike (blue ones) specific pads, after two rides I'd had enough and bought another set of the CL ones.
the second best ive used and good value are the uberbike white ones.. good wear and value with decent braking performance
Polar
265
364
Norway
Hi everyone,
Galfer purple is what you're looking for
BRAAAAP
England
Thanks man, I'll have a look into them
Downhillr
233
111
SF Bay, California
Hi everyone,
I and several in riding group here in NorCal using MTX Gold for e-bikes and DH/Park bikes. Good power, modulation and fade resistance without rapid wear or chewing up rotors.
Plummet
Flash Git
Mar 16, 2023
972
1,399
New Zealand
I use sinteered oe pads.
Tried non oe over the years. Not as good.
I'm very skeptical that you can gain much more power at all with pad material.
Its physics after all! There isn't any change in leverage or pad size.
Crank up to a 220 front and 200 back rotor and that should do it.
Jhagst
75
64
California Bay Area
They are good, but it's a shame they don't last long. At least the power pads.
True, but for $20 who cares. I keep some extras in the truck and at home. Braking performance is great, silent, and doesn’t prematurely wear your rotors. I’d rather replace them often and enjoy good, quiet brakes.
AlumiPro
149
80
California
I’m running Cascade North Fork Calipers with my Stealth Ultimate Codes. They made a noticeable difference. I’m currently running the HS2 220mm/200mm Rotors with the SRAM organic/alum plate pads. I’m still looking for a bit more bite power (I’m used to riding with Magura MT7’s), so I just ordered 4 sets of Trickstuff Power pads. Looking forward to trying them out when they arrive!
I have a new extra set of HS2 rotors, question; should I bed the new TrickStuff pads with the new rotors or can I bed them with the existing rotors? (Only 40miles on the existing rotors with the SRAM organic pads)
Downhillr
233
111
SF Bay, California
Ive had success for years just wiping rotors with auto brake cleaner (wear vinyl gloves) 1st, then lightly scuff contact surface with fine emery cloth, rewipe rotors & bed-in new pads.
Downhillr
233
111
SF Bay, California
Pad material is actually critical to performance on auto, moto, bicycle. Using street auto (sports car) at track with stock pads a couple fast straight into turn and youll bevin the weeds due to extreme fade, switching to track pad (sintered or ceramic) on same stock brakes makes all the difference. Try longer DH park descents on most stock organic pads vs ceramic or sintered and you’ll see the difference quickly.
Plummet
Flash Git
Mar 16, 2023
972
1,399
New Zealand
I only use sintered and have not found pads with more power than OE pads.
AlumiPro
149
80
California
I think I’ll bed the TrickStuff Power pads into my existing rotors(once cleaned & scuffed), and try out an unused set of SRAM Sintered pads with my new set of rotors. This way I can swap from one setup to the other quickly to see which feels and sounds the best….I never tried the SRAM Sintered pads that came with my Codes, as I don’t ride in mud and rain and worried they’d be laud.
Nomad1
222
72
03818
Hi everyone,
seriously consider changing out the brake setup as a option many people find they don't like Sram brakes compared to others. I'm not saying change them but, you may find in the end that ends up being the best route. You may Also find you like your Sram brakes.
Chairman
211
115
Nz
I am on the side of pads do make a difference. Best I have used are Magura race pads but you need to keep them working hard. When they are cold they are hopeless. My go to are galfer purple. Strong and last well
Durrti
147
150
California
I’ve had the exact opposite experience with the race pads, had them fade twice now when hot and needed. Just put performance pads back in.
Downhillr
233
111
SF Bay, California
That reminds me of my 1968 Plymouth Road Runner “muscle car”… I was fortunate to get one of 2500 factory cars specifically modified to meet homologation rules for NASCAR racing (bigger brakes, stronger transmission, stiffer suspension). I thought geez, since I got bigger brakes they would work even better with race pads… well, on a circle track at 150-180 mph I bet they’re great, however, on the street & cold you end up blowing through the 4 way stop at bottom of street hill and ending up in a neighbor’s planter!
Chairman
211
115
Nz
Another carer here. If my braking performance is compromised at all my whole riding performance degenerates but that's just me. I am sure there are plenty of others that it doesn't affect to anything like the same amount
Durrti
147
150
California
Ride report: Magura performance pads feel better in all aspects over the Magura race pads. Stopping power, modulation, and noise is much better with the performance pads.
KnollyBro
874
2,172
Vancouver
I have only every used OE metal pads on my CODE RSC brakes and am happy with their performance. I am giving these ones a try cuz I am SURE all pads end up doing the same 2 things, they stop the bike and they wear out. Its only a matter of time and money. What could possibly go wrong? :unsure:
4.23£ 49% OFF|Metal Bicycle Disc Brake Pads | Sram Metal Disc Brake Pads | Brake Pad Sram Guide 4 - 4 - Aliexpress
RiderOnTheStorm
What are we debating here? Do brake pads effect braking power? I think we all know the obvious answer to this question. Of course, it does. Depending on pad compound used, braking power will be different.
OP is looking to improve braking power with different pads. May be the question is which pad material or compound provides the best braking/stopping power regardless of brands? How do sintered pads compare to kevlar or ceramic pads?
Plummet
Flash Git
Mar 16, 2023
972
1,399
New Zealand
I'm debating that aftermarket pads can achieve more braking power than original equipment pads.
In my experience at best they equal the best original equipment pad material.
So...
If you are significantly light on power, pads wont fix the problem. The solution is bigger rotors and or different brake design.
527K
