For Sale (BIKE) 2022 Specialized Kenevo SL S4 S4: 5800
LeeG
13
14
Bike / Product Year: 2022
Manufacturer: Specialized
Model: Kenevo SL S4
Size S4
Asking Price: 5800
Location Buckie, Scotland
Description For sale is my Specialized Kenevo SL in size S4
The bike was originally purchased as an expert build however there was a warranty issue with the frame and it was replaced with an S-Works frame in January 2023.
The frame has been used for 5 rides only and was invisiframed when it arrived.
The motor and battery was transferred over to this frame by specialized and has covered 587km. Battery remains at 100% health.
Standard 'expert' level spec with the exception of the fox float X2 factory that came with the new frame. So the drivetrain remains as SRAM X01 level spec. The fork is the Fox 38 performance elite version with the grip 2 damper.
Brakes have been upgraded to the best ones currently on the market - Hope tech 4 levers with the V4 calipers. Discs are SRAM HS2 rotors 220mm front, 200mm rear.
Burgtec 42.5mm stem with deity 38mm rise bars cut to 775mm.
Bike also comes with the range extender 160wh battery which is now on a convenient fidlock mount. Standard cage also available.
Tyres fitted are the new specialized hillbilly's in grid gravity casing in the T9 rubber compound. Optional tyres are the standard butchers in grid trail T9/T7 front/rear.
Further option is to swap out the fox X2 shock to a brand new Rockshox super deluxe ultimate coil (2023) which has been custom tuned to the frame by J-Tech.
Minor marks to the cranks and a small scratch on the bars. Pictured. Otherwise immaculate.
Contact me for further information.
Collection only.
527K
