Sold 2022 Specialized Kenevo SL S3: $4500
RidingLA
Palm Springs CA
Bike / Product Year: 2022
Manufacturer: Specialized
Model: Kenevo SL
Size S3
Asking Price: 4850
Location Palm Springs CA
Description If you’re looking for a like-new carbon Kenevo that has lived a calm and uneventful existence, only ridden on fire roads, you’ve found the right bike. 100% battery life, low charge cycles (see screenshot).
Upgrades:
  • Frame wrap
  • Magura MT7 Pro Brakes
  • Renthal FatBar 35mm with fresh grips
  • Platform pedals
  • Front & Rear mud guards
Comes with
  • The original battery charger
  • Bottle holder
It’s fully sorted, tuned, ready for its new owner.
I am located in Palm Springs CA, but willing to drive to meet a serious buyer in the greater SoCal Area.
Can also ship nationally via BikeFlights at buyer’s expense.
Cheers!
Below are Specs straight from Specialized
Stem
Alloy Trail Stem, 35mm bar bore
Tape
Specialized Trail Grips
Saddle
Bridge Comp, Hollow Cr-mo rails, 155/143mm
SeatPost
X-Fusion Manic, infinite adjustable, two-bolt head, bottom mount cable routing, remote SLR LE lever, 34.9mm, S2: 125mm, S3/S4: 150mm, S5: 170mm
Rear Derailleur
SRAM GX Eagle, 12-speed
Cassette
Sram XG-1275, 12-speed, 10-52t
Chain
SRAM NX Eagle, 12-speed
Crankset
Praxis Forged/M30 Spindle Interface
Chainrings
SRAM X-Sync Eagle, 94 BCD, 32T, alloy
Rims
Specialized 29, hookless alloy, 30mm inner width, tubeless ready
Front Hub
Alloy, sealed cartridge bearings, 15x110mm thru-axle, 28h
Spokes
DT Swiss Industry
Front Tire
Butcher, GRID TRAIL casing, GRIPTON® T9 compound, 2Bliss Ready, 29x2.3"
Inner Tubes
Tubeless, with sealant, Presta valve
Rear Hub
Alloy, sealed cartridge bearings, 148mmx12mm thru-axle, 28h
Rear Tire
Butcher, GRID TRAIL casing, GRIPTON® T7 compound, 2Bliss Ready, 29x2.3"
Seat Binder
Alloy, 38.6mm
Frame
FACT 11m full carbon, 29", full internal cable routing, 148mm spacing, fully sealed cartridge bearings, 170mm rear travel, geo adjust head tube, geo adjust horst pivot
Motor
Specialized SL 1.1, custom lightweight motor
Battery
Specialized SL1-320, fully integrated, 320Wh
Charger
Custom charger, 48V System w/ SL system charger plug
UI/Remote
Specialized MasterMind TCU, ANT+/Bluetooth®, w/Handlebar remote
Wiring Harness
Custom Specialized wiring harness
Rear Shock
FOX FLOAT X Performance, LSR, 2-position lever, 62.5x230mm
Fork
FOX FLOAT 36 RHYTHM 29, GRIP damper, 44mm offset, 2-position sweep adjust, 15x110mm, 1.5" tapered steerer, 170mm travel
SWAT
SWAT CC, integrated tool and chain tool with spare link in steerer tube
_
It's an incredible superlight (SL) Enduro that was only used as a trail bike, like a S2 S4 Levo but without the price of the S-works. Think of it like a stumpjumper or rockhopper but emtb with pedal assist. Has the Fox 36 which is lighter than the Fox 38. I am 5’10 and could have gone with either the S3 or S4, but found the slightly smaller S3 to be more playful.
RidingLA
Palm Springs CA
Bump: I do not enjoy selling bikes (2 more flakes, and I was holding it for both!). This is a serious deal for a serious buyer - first to show up wins :D
527K
