2021 Orbea Wild FS M20 (Ebike) Rear Shock
RKDivemaster
GA
Group, sry if this has been asked (couldn't find anything on search)
I finally managed to blow out my rear shock (factory)
FOX FLOAT DPS Performance, EVOL LV, 3-position adjust, custom tune, trunnion mount, 205mm x 65mm
Since this appears to have been tailored specifically to Orbea for this bike, finding a suitable replacement with the exact bore and stroke has been limited.
The ask; anyone have an opinion on a replacement? minor changes in the specs? Interested in remote reservoir models if i can find one that will fit and work with this bike
Thank you in Advance
RK
Durrti
148
151
California
It’s actually a fairly common size and you can get most shocks is this size. The only caution is to make sure any reservoir shocks fit. I think all fox will, new rockshox coil will not.
Mteam
1,797
1,737
gone
Rockshox deluxe and super deluxe air won't fit. The shock fouls the frame at the bottom where the trunnion mounts
esmiralda_h
12
19
The damper selection is very limited.
DVO Jade fits in but compression not accessible.
Rock Shox Air RC2T 2023 rebound and air valve accessibility modest, compression adjustment probably hits the frame when compressing.
CC Kitsuma Coil / Air no assembly possible.
Öhlins ttx 22m coil with normal AGB fits.
Manitou Mara Pro Accessibility of all adjusters and valve is good.
528K
