2021 Focus Jam2 6.9 C.I.S Cable routing and Mac-Ride
Stu12a
8
Hey Guys,
Long shot but i was wondering if anyone knows much about the C.I.S Cable routing on the new Jam. I have a Mac-Ride which requires a 10mm spacer to be inserted on the stem, However with the cable routing, it seems like it is impossible. I've mounted the spacer on top of the stem and it feels sturdy but its on a fair angle for the kids to sit and not sure if it will last. Not something i want coming off. Do i get the cables re routed down the side of the frame as the older modles have done or even pop a spacer out and just have the cables loop over that spacer?
Stu12a
8
chamedu
Spain
Hello here.
I am running with same problem with ma sam2.
Did you find a solution or you keep it like it was in the picture.
quasimoto
Slovakia
Hi I have Mac Ride and I am considering to buy Focus Thron2 6.8.
But I do not know how to put there the Mac Ride adapter.
Did you find any solution?
Like rerouting of cables?
I see some brands have special spacers with opens for cables, did anyone try to use normal stem and then to route cables into the spacer?
Or does Focus have some special spacer so it will not work?
See the picture attached, its Cube.
Fuego del norte
Pays de Gex
Sorry to bump up an old thread. I'm encountering the same problem with my new spectral: ON. It's been some time. Have you found a solution?
Even though the bike was at a discount, I consider returning it if I can't find a solution.
Would deeply appreciate the help.
529K
