Do's and Don'ts for e-bike battery care. What do you do to keep your battery performing at its best?
6,211
4,713
There are specific storage and charging temperature limits (1)...............and there are recommendations regarding temperature and humidity to ensure maximum longevity of the battery (2). If you have to store the bike/battery in a shed or garage all year round ( in the UK) you merely risk it not performing to maximum capacity for as long as one stored indoors (2). The difference is probably not that great!!
PS if you are concerned a bout bike security when stored in a shed or garage because it has a non removeable battery, remove the wheels and keep them indoors...........on most bikes it is a 2 minute job and a bike with no wheels is going to be less attractive.
I store my bikes in the house but if I am working on a bike and it has to stay in the garage on a workstand for a few days, I remove the battery and both wheels and keep them indoors. Worse case scenario, the bike gets nicked but at least I have a battery and 2 wheels :LOL:
TimC7
Ovine Assaulter
Apr 22, 2023
211
831
Shimano (and others) say if you operate below the minimum temps you won't damage the battery, and performance/capacity will return to normal when temps go back up so no worries with garage storage (in the UK).
Planemo
593
698
Essex UK
Yeah most li-ions are specced down to a -20 degC operating/storage temp so normally well within UK temps. All that happens when discharging them at these temps is a range loss which can be a lot more than many think.
Of note though is that charging temp should ideally be above 0~10deg C depending on what specific cell is used (eg Sanyo GA18650 being 10deg, Samsung 21700 being 0 deg)....which could impact UK temps. My battery is always stored in the house so not a problem but it wouldn't be ideal to charge an empty pack immediately after it's been sitting in a shed at -10 overnight.
Binhill1
🍊 Tango Man 🍊
Mar 7, 2019
2,825
4,233
I suppose mine occasionally gets left now and then probably not when it's baltic though and its a faff running a cable from house to shed for charging . I should have put power in there years ago it probably won't happen now. I was after a gravel bike with maybe a 500 battery thats removable as I am intending touring. Unless I'm willing to pay a fortune its not going to happen. Can't wheel a bike in to a cafe but they probably let you charge a battery. Worse scenario you pay something.
Ali_Foto
29
Dubai
One question ; in TQ e-bike system , the e-bike use the range extender battery power first unit it comes to 0 % then switch to main battery so, which one is better to do,
1)connect the range extender when the main battery is discharged to less than 10%
2)The range extender battery to be connected to the e-bike permanently and charge it with main one together.
TimC7
Ovine Assaulter
Apr 22, 2023
211
831
Maybe read the manual?
Ali_Foto
29
Dubai
In the manual, it has mentioned that charge the range extender immediately when it reached to below 5% , since range extender discharged first then TQ drive switch to main battery, so it is strange.
529K
