This is a non EMTB question, but hopefully someone can help me anyway…
I bought my daughter a Specialized Rockhopper for her birthday. She’s going to be 9, and I’ve got her an XS ‘Expert’ model. Grandma is the one buying it, so I had to get the best deal possible. This meant ordering online…
It’s here now, and yesterday I took it out of the box, put the bars and wheels on… and fitted some nice purple grips, stem cap, pedals to add a bit of colour.
I’ve got it in my stand, so made a wee adjustment to the brakes to stop them rubbing, and ran through the gears.
1 to 3 were fine, but 4/5/6/7 would all skip, then 8-12 were fine. The B Gap wasn’t set quite right, so I fixed that, and then started fiddling.
I’ve had an Eagle drivetrain on my Stumpy since they first came out, so I’ve adjusted that several times. I’ve also fitted XX1 AXS to my Levo SL, then GX AXS to my Stumpy later on, and eventually an XX Transmission to my SL.
Although I’m no stranger to adjusting them, I’m finding this one impossible.
I’ve spent the last 4 hours this evening, and about 90 mins yesterday fannying about with it, and going back to basics and watching YouTube videos! I must’ve watched about 20 different ones, but they all go though the same method…
Chain on smallest cog.
Undo the cable.
Using the upper limit screw, make sure the chain line is straight.
Pull cable taut (not tight) and do up the bolt.
Make sure it shifts up a gear per click.
Once at the top cog adjust the lower limit screw.
Shifting ‘should’ be fine.
I’ve done this so many times now. If I have it perfect at the top and bottom, it skips gears 4/5/6.
On the flip side, I can get it to shift perfectly from about 3-12, but 1/2 sound like crap… or alternatively, I can get 1-8 fine, and 9-12 skip and sound dreadful.
I’ve also tried several barrel adjustments too, but that doesn’t help either.
Nothing ‘looks’ bent or damaged, but it has been shipped in a box - so it is possible it could have been bounced about on the way.
Although her birthday isn’t until the end of the month, she has seen it (difficult to hide!) and since we’re away on holiday on her birthday, I figured we could maybe test it out this weekend… but the way it’s going, I feel like I’m going to have to bite the bullet and try and book an appointment at a local shop.
Any advice appreciated!
Undo the cable.
